Question about Nintendo Wii Console
RE CONNECTING CONTROLLER AFTER CHANGING BATTERIES
WE ORIGINALLY HAD 2 CONTROLLERS BUT ONE HAS BEEN DAMAGED DUE TO FRUSTRATION!!!
NOW WITH JUST THE 1 CONTROLLER, BATTERY WAS LOW SO CHANGED THE BATTERY AND NOW CAN'T GET IT TO PICK UP CONTROLLER PLEASE HELP.
PS CAN'T FIND INSTRUCTIONS!!
    Problem Solver:
  • 18 Answers
The remote it should automatically connect even after changing the batteries out. Press the power button on the remote, and if it doesn't work use the sync button below the battery cover.
Posted on May 09, 2008
Harley evo will bog and sputter interminently, like its running on 1 cylinder
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
Good luck
Feb 04, 2014 | Harley Davidson Motorcycles
My phenom controller wont connect unless connected to usb
1 Hold your controller like you normally would when playing a game, and then flip it over. 2 Use a paperclip to hit the Reset button on the back of your controller. The button is located to the right of the screw found above the sticker on the back of the controller. 3 Connect your controller to your PlayStation 3 using the USB cable. 4 Press the PS button on the front of the controller. The system will boot up, and your controller is now reset and synced with your PlayStation 3. Tips & Warnings: If you use the same controller for multiple PS3 systems, you should do this whenever you notice problems with your controller, since it could resolve the issue. Don't press the reset button on the back of the controller too hard. Otherwise you risk damaging your controller.
Source(s):
http://www.dwtechz.com/
Jan 24, 2014 | dreamGEAR 1012587 Phenom Wireless...
Where is the sensor for 2007 softtail?
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 17, 2014 | 2007 Harley Davidson FXSTC Softail Custom
Where is the sensor for a 2007 softtail motorcycle
Hi Gloria, and the usual suspects are:
For a prime suspect please visit website below: Good luck
Jan 17, 2014 | Harley Davidson Motorcycles
01 fatboy ,running bad ,cutting out intermitingly .tank is clean ,changed tap
Hi Mac1, and the usual suspects are:
Jan 13, 2014 | 2003 Harley Davidson FLSTC Heritage...
Engine is stalling
Hi Chris, and the usual suspects are:
Harley Diagnostic Codes 04 to Present
Sep 04, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
Harley sportster 2000 1200xls backfires and sputters.
Harley Davidson Sportster error codes and how to access them
Jul 29, 2012 | Harley Davidson XL 1200 C Sportster Custom...
Engine is running rough. Have changed plugs, battery, and air filter
Hi Andrew, and the usual suspects are:
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor or intake seals.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Jul 06, 2012 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
Faulty speakers
This is due following reasons.
1.Panel might have damaged.
2.Duplicat panel may be you are using.
3.Broken.
just change the Panel with Original one your issue should resolve.
Jan 28, 2009 | Nokia 5310 Cellular Phone
Nintendo Wii Console Logo
69 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
