Question about Hoover HP6130 Front Load Washer
How to operate front loading hoover wa 420? - Hoover HP6130 Front Load Washer
Service/repair facility in the Pacific Northwest
  • OREGON ASE Supplies
    2321 NE Argyle, Suite C
    Portland, OR 97211
    Ph. 503-288-0100
  • WASHINGTON S3 Maritime LLC
    100-2296 W. Commdore Way
    Seattle, WA 98199
    Ph. 206-420-4932
  • Aug 18, 2010 | Xantrex Technology Xantrex 458 10 12...
    I just moved into a furnished apartment with a Hoover washer. Please could you explain how to operate it. I have used it twice, but both times it took at least 3 hours to complete the washing.
    this is probably because most front load washer heat the water. check if you can adjust temperature or turn off,or check if the washer has a quick cycle for example quick 30 minute cycle.good luck keep me informed
    Jun 22, 2010 | Hoover AAA160 Front Load Washer
    43142 Front Load Washer: There is a step by step operation to put the HE wa...
    Is that the right model number don't look like kenmore model number.
    May 17, 2010 | Kenmore 43142 Front Load Washer
    Hoover washing machine wont spin
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Nov 01, 2009 | Hoover UltraCare HC6 160E Front Load...
    I need instructions for an Indesit WA 126
    In your browser box, type in Indesit user manual, and click on the appropiate link.
    Please rate my solution.
    Thanks.
    Jul 16, 2009 | Indesit WA 125 Front Load Washer
    Will not start
    Basically this is what they call a demo screen.
    The only way to make it operate is in the manual.
    If you don't have one then try downloading one from the hoover website.
    Jun 13, 2009 | Hoover AAA160 Front Load Washer
    Hoover " eco wave 5" wa 1000 help
    haha found out that just afore the pump in the hose was 2 pounds! ! Hehe, the coin saved the bill! :-)
    May 10, 2008 | Zanussi FLA1001W Front Load Washer
    MAchine Boils the water
    if the temp sensor is operating ok but the element doesnt switch off there may be a problem with the power board/timer just follow the wires back to find problem.
    Oct 18, 2007 | Hoover AL130 Front Load Washer
    Hoover HP6130 Front Load Washer Logo
    330 people viewed this question
    Top Hoover Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
