Question about Sperry Instruments HST401 Voltage Continuity Tester
How do you check a flash light bulb to see if its ok
  • 905 Answers
If the bulb is a regular and typical flashlight bulb, then a simple resistance measurement across the bulb will tell you your answer. If you get resistance, the bulb is good. If not, then the bulb is bad (broken filament).
The manual for your 401 is here. Follow the instructions in it (second column) for checking continuity of an unpowered device.
If your tester doesn't appear to be working as it should, then it likely is time for new batteries, or it has been exposed to a voltage higher than 250vac, and is damaged.
Posted on Aug 31, 2010
I have a Chevrolet cobalt and the left turn signal will not work the inside light on dash flashes fast. I have changed the light bulb still doesn't work.
Fast flashing usually indicates that one of the exterior bulbs isn't functioning. You've checked front and rear signal lights, right? If the bulb is good, it could be corrosion in the socket, bad ground, broken wire, etc.
Oct 16, 2015 | 2006 Chevrolet Cobalt
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
Why would running lamps quit, left headlight is very dim DRL light on dash flashing?
Have your alternator checked yet? Your alternator is what actually powers all of your devices and lights when the car is running. When it is failing it will cause lights to dim. Checking connections, fuses and your alternator should lead you to a good start! Good luck!
Nov 12, 2014 | Cars & Trucks
Turn signal flashing fast
check all your bulbs are ok. change bulbs only as a pair not just one side.and of the same make .and company.
Dec 11, 2013 | GMC Cars & Trucks
Right turn signal lights flash very fast
check to see if the front or rear bulb is burned out most of the time one bulb burns out causing a faster flash on that side.
Apr 18, 2013 | 1997 Dodge Neon
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
Aug 15, 2012 | 2004 Buick LeSabre
I havea 1995 Ford Fiesta and the indictor lamps(front and rear) only work on the right hand side, if you try to indicator to turn left you just get a ticking from behind the instrument panel and neither...
Try the hazard lights to check if all four lights flash, if not then check the bulbs. If the bulbs are ok check the contacts and the connections. if all all these are ok the problem could be the indicator switch. The flasher unit is fitted in the circuit before the indicator switch, that is why it operated although the lights might not.
Jan 17, 2011 | Ford Fiesta Cars & Trucks
2001 Toyota Avalon - Rear signals
Check the front lights. Usually if i flashes fast it indicate a bulb is out on that side.
Aug 02, 2009 | 2001 Toyota Avalon
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Sperry Instruments HST401 Voltage Continuity Tester Logo
55 people viewed this question
Top Sperry Instruments Measuring Tools & Sensors Experts
Steve
Bruce Foote
Level 1 Expert
Vuk B
Are you a Sperry Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
