Question about Samsung RS2630SH Side by Side Refrigerator
My Lower freezer is too cool n ice build up inside there.... The top side working properly. What is this cause to happen?
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Frost and ice is building up on the right side vent in the back of the freezer. What would cause this?
Its defrost issue.The defrost thermostat,timer and defrost assembly. Any of the one can be faulty causing these.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Kenmore 64802 Top Freezer Refrigerator
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The bottom part of my refrigerator is not cooling properly.
Something inside the freezer compartment may be causing this. Unplug the refrigerator and remove the rear panel inside the freezer to examine the evaporator coil. It may not be defrosting properly and blocking the air flow to the lower section. Let me know what you find. If snow and ice is present defrost with a hair dryer and we need to check the defrost heater a d defrost components. Sea Breeze
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
The freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
