Question about Garden
The mower blades will not turn. Tractor runs fine but the blades will not turn when the pto is switched on. There is nothing block or holding the blades. They just will no longer rotate when the pto is ingaged. Why?
  • 855 Answers
You don't say what type mower you have so here is some general things to check. You need to check if the belt if belt driven blades is there and properly adjusted. If that is fine check that the PTO switch is working. For this use a test light or multi meter to see if the ground is good, that it is getting current, and that current is going thru the switch when turned on. If all that is working check to see if the current is getting to the PTO. As you can see there is a number of things that can cause this problem so if you need further help please let us know the details and make and model of your mower for more detailed procedures for repairing the mower.
Posted on Aug 31, 2010
  • matpaxton Apr 29, 2012
    I have a cub cadet LT 1018, 18.5 hp. The blades engage but when I accelerate they shut off. This Is a 42" deck. I was told by a cub cadet dealer that it was the pto clutch, $350
  • 490 Answers
Not much to go on, but sounds like your belt is off a pully. I can give a better answer with more info, but talke a look at belt system first. We will get you going.
Farmerbear
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
PTO won't turn on.
The belts may be off pulleys and PTO shutting tractor off is a safety item so if you get off mower with blades engaged you will not get injured Tom. Thank you and good luck. Please leave some feedback for I am fairly new.
Jul 12, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
MY TRACTOR RUNS FINE& STOPS LIKE IT SHOULD. THE BLADES DO NOT TURN WITH THE PTO SWITCH ENGAGED
if this is a newer mower then the problem is usually a safty switch is not being completed and this is stopping the blades from turning on, most mowers have a switch under the seat that has to be shorted out in order for the pto to work, this can be checked by connecting the two wires going to the switch together, and seeing if this solves the problem. Does it sound like the pto is trying to turn on if this is the case then you might find you have a siezed up bearing that is stopping the pto from engaging but my guess is a safty switch is malfunctioning and causing the pto tp not turn on, Hope This Helps Don
Nov 10, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Engine starts, but stalls when clutch is released.
The is a safety switch located underneath the mower, in the dashboard area. This switch will not pass voltage to the ignition system unless the pedal is depressed, or the deck is not all the way up. However, your culprit is most likely the pto (power take off) switch on the dash that engages the blades. It will not allow the mower to start, if pulled, and if faulty will shut off ignition power when you release the pedal. First. You'll need a volunteer to sit on the mower and operate the controls.  Now put the deck down and with the pedal depressed start the engine. Nothing should happen, if it does replace the deck switch Sears part number #176138 mentioned above. Now raise the deck and release the pedal. Again, nothing should happen. Same solution if it does. If nothing happens on both tests the switch is ok. NOW. Behind the dash, find the pto switch, and squeeze the sides, depressing two clips that hold it in the dash. You should now be able to slide it though the dash, wiring attached. Unplug the switch. With pedal depressed, deck up, someone sitting on the seat, start the mower. Now release the pedal (making sure to block the wheels and have the transmission handle is in the neutral position. If the engine continues to run, you found the problem. Replace the PTO switch. Sears part number # 174651. Also, check the plug to the pto, ignition and deck switches for corrosion as this is a common problem, though not likely to cause yours, it could. Good luck, and please let us know the outcome, good or bad. Thanks so much.
Nov 12, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
