Question about Nokia 5800 XpressMusic Smartphone
I have nokia 5800 xpressmusic phone. i wanna activate 3G on that. it shows the 3G icon but no signal my question is how to activate 3G thank you
Posted on Jan 01, 2011
    New Friend:
If you don't use 3g it is but wise to turn it off. Go to Settings-->connectivity-->network-->netw... mode-->select GSM, and restart ur phone.
Your battery backup will also slightly improve by turning off 3g..
Posted on Sep 20, 2013
SOURCE:
Nokia 5800 xpressmusic can't connect to network
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Oct 14, 2012 | Nokia 5800 XpressMusic Smartphone
Hello, I got a used nokia 5800 phone from canada. I got it unlockd, Phone works now , I can made calls, but 3G signal not indicating althogh the phone in dual mode . Where is the fault ? Please help...
Check the bands that your phone is capable of go with and check bands with service provider also check coverage with them maybe you are not in a 3g service area or not compatible with the band they provide 3g on.
Sep 21, 2011 | Nokia 5800 XpressMusic Smartphone
I activated bsnl GPRS & 3G. .I send msg NOKIA 5800 TO 58355 ,replay comes incorrect formet. 3G sttings not coming to my phone. & also try to get form online but soutzone link not openng. So wht...
NOKIA 5800 TO 58355 The sms you have sent is right.Sometimes it may occur due network problem so in my comment please repeat the procedure.Good luck
Aug 05, 2011 | Nokia 5800 XpressMusic Smartphone
Sir, By mistake i applied 3G option in my nokia 5800 mobile, now i want to disconnect/close that option, can u guide me in this regards, that where i can find option to close 3G option in my...
Select Menu > Settings > Connectivity > Network
Then select from the following:
"Network mode" - Allows you to select which network to use.
"Dual mode" means the device uses the GSM or 3G/UMTS network automatically
Your device will automatically switch between GSM and 3G/UMTS
networks.
More info is in the Nokia 5800 XpressMusic user manual at:
http://nds1.nokia.com/phones/files/guides/Nokia_5800_XpressMusic_UG_en.pdf
Feb 26, 2011 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 xpressmusic wont pair with my nokia hs-44 bluetooth handsfree please help me thanks
the iphone 3g bluetooth is at present for headsets/handsfree devices only and cannot link/pair with anything else (phones/pc etc) it has been deliberately crippled to force file transfer etc to be done exclusively through itunes or formate
rate my answers too
Dec 28, 2010 | Nokia 5800 XpressMusic Smartphone
I wanna activate 3G video calls in my nokia x6 phone
you will be need an 3g sim which you can get from your service provider,then go to settings of your phone and select dual mode
hope this will be help
Nov 26, 2010 | Nokia 5800 XpressMusic Smartphone
When i turn on the nokia 5800 it shows sometimes the antena or 3.5 g or 3g but it won't last more than two minutes and then 0 coverage the bars and the at&t icon both gone, thanks. Also the gps...
ur phon have 3G support when u turn on the cell it search for the 3G tower so its shows like that got o settings in network settings switch it in to dual mode to single mode or GSM only
Nov 09, 2010 | Nokia 5800 XpressMusic Smartphone
How to use the VIDEO CALL?? and the MMS
Video call can be used by using a 3g sim and activating it,but both phones must have 3g requirements to use it.
Oct 09, 2010 | Nokia 5800 XpressMusic Smartphone
I am using the 5800 xpress .Setting and some other icon missing in my phone.How can i get it back?
well u can restore your cell try this way
5800 Hard Reset
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
Mar 02, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
1,479 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
