Question about Emerson MW8107WA Microwave Oven
My emerson mw8107wa microwave oven makes a very loud grinding noise when running. At first I thought it was maybe the turntable not being properly seated, but no matter how often I remove and replace it, the sound doesn't go away. In fact, it's gotten worse. Thanks in advance for helping with this, Kitty Shields
  • 185 Answers
If it doesn't heat; it's probably a shorted magnetron and/or diode.
Posted on Aug 31, 2010
  • shieldsk Aug 31, 2010
    Thanks so much for the quick response! I guess it would have helped though if I had said that it does heat. It works; just makes that awful noise, but not every time. Any other ideas? Thanks again ~ K
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
Microwave turns on, turntable turns but does not heat
did you check the heater in microwave , it turned .so maybe there is something wrong with the heater .
home light bulbs
Feb 15, 2012 | Emerson MW8107WA Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Microwave mw8115ss the turntable makes a loud grinding noise when it's going around.
replac the drive motor . if its not the supports ( or wheels that it turns on ) ****
Jan 09, 2010 | Emerson MW8108P Microwave Oven
I need a new glass shelf for Model # MW8107WA
The original part number was 441X335A10, which is no longer available, but you can get a direct substitute here.
Jul 09, 2009 | Emerson MW8626W Microwave Oven
Panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Glass top of oven
This is something out of an Emerson MW8107WA microwave?
I knew they used glass turntable trays...
If this is not right, could you repost the correct brand and model number?
Thanks very much.
Nov 10, 2007 | Emerson MW8107WA Microwave Oven
Turntable failure
You probably have a defective turntable motor. They are fairly simple to replace and generally runs about $30-$35. You can access the motor by removing the bottom panel from the microwave. There are a couple of wire connectors and a few screws holding it in. You will, of course need to secure the main power and/or unplug the unit first. The spindle that the carousel and plate ride on, just pops off by lifting straight up from the inside of the oven cavity. Let me know if you need any further advice. I hope this helps you.
Aug 02, 2007 | Emerson MW8107WA Microwave Oven
Emerson MW8107WA Microwave Oven Logo
115 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
