Question about MedWeigh MS3300 High Capacity Medical Scale
Hello; We have an MS 3300 Digital High Capacity Scale that is reading 10+lbs over what it should be. Purchased in 2008. The manuals have been misplaced. How do we recalibrate the scale to read the correct weight? Thanks for your attention to this question. Regards Marilynn Georgas Director: Fitness, Health and Wellness Fredericton YMCA Fredericton, New Brunswick
My batteries are new, the scale reads error and will not reset. I have taken batteries out and changed it from lbs to kgs and moved it and nothing works? Please advise.
I was surprised to learn that SOME digital scales are VERY particular about the batteries users install! (I-KNOW!)
LOOK CLOSELY to see what battery your scale specifies.
Please let us know how this works for you?
Anthony
Jan 29, 2018 | The Health & Beauty
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
I have a Seca model 707 waist high digital scale and starting last month it started going 5 lbs heavy for a few weeks than the correct weght now its back to about 5 lbs heavy. is this fixable?
get out the operation manual and look in the index or glossary for the "calibration" routine. it is a failry simple process of recalibration. As these units age the solid state components inside chage a little bit. it needs to be reset, that's all
Mar 11, 2011 | Seca 710 Waist High Mechanical Balance...
My scale adds anywhere from 5 lbs to 35 lbs to my family's weight. I just had my daughter weighed yesterday and this scale added 5 lbs and when my husband or I get on it, it adds anywhere from 30 to 35 lbs...
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Dec 10, 2010 | Homedics Glass Digital Scale - Advanced...
Just purchased the Ideaworks Large Capacity Bath Scale with infrared receiver and I can't get it to display the weight. The receiver seems to be working (can set clock, lbs, etc. . . ) but nothing happens...
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Apr 22, 2010 | Jobar International Ideaworks Remote Read...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Hello, I just purchased a replacement memory card and when I install it is says on the screen "check sd card" after reading the packaging for the new card I realized it says camera may not support SDHC...
HC stands for high capacity meaning 4g or more. Your camera manual should tell you if you can use the card. Maybe all you need to do is make sure the slide switch on the side of the card is unlocked and then you should format the card in the camera.
Dec 08, 2009 | Samsung Digimax S500 Digital Camera
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
MedWeigh MS3300 High Capacity Medical Scale Logo
66 people viewed this question
Top MedWeigh Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a MedWeigh Health and Beauty Expert? Answer questions, earn points and help others
