Question about Refrigerators
Kenmore side-by-side refrigerator compartment freezes no matter what setting control knob is on. But If I turn refrigerator control all the way off it will warm up. Turn it up just a notch and eventually will freeze up again. It appears that the temperature control is messed up. Doesn't want to turn off once temperature setting is reached. Freezer seems to be working fine.
    President:
  • 3,773 Answers
The cold control sounds like it does need replacing.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Refrigerator and freezer is freezing everything
Its either a bad defrost timer not kicking on, bad main control board or the temp switch. Sorry not much help but the only way to really tell is check with a ohlm meteor and eliminate each part.
Mar 04, 2015 | Kenmore 26.5 cu. ft. Side-by-Side...
My Hoover 400 cyclic refrigerator motor won't stop running.
what setting do you have the control knob set to ?
Feb 12, 2015 | Hoover Refrigerators
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Refrigerator part of coil freezing up, what would be the problem?
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Jul 25, 2013 | Refrigerators
Kenmore side by side Model #106.55532400 Orignally the frig. side would not cooled down below 40F even when the digital control was lower to 33F. The unit was unloaded and turned off for 24 hours, doors...
Yes the thermister is the electronic thermostat...on models such as yours that has a computer control a thermister is used..on models that the knob is turned to set the temp. and has no digital dispay a thermostat is used
The part number for the thermister is 2188819
It fits by air damper in the fresh food compartment in the upper left corner of the fresh food compartment
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
Oct 02, 2007 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
