Question about Giorgio Armani Emporio Armani Ar0562 Classic Watch
Need to change battery and cannot open back of watch
  • 490 Answers
Howdy, as a do-it-yourself-er, I feel like I should be able to change a battery on a watch pretty easily, but i also have difficult to open model. I take mine to the pharmacy and they do it for the cost of the battery. Local hardware, and jewelry stores also do this. Some, few, areas still have watch repair shops ( best option). Some cases are pressurized, I understand.
Well, lots of info, but I don't know how much help:)
Regards, Farmerbear
Posted on Aug 31, 2010
How to change battery -can't open case on Nouveau quartz men's watch
Take it to K-Mart jewelry dept. and ask them to take the back off to determine the battery you need. They'll do it and only charge you for the battery.
Jul 26, 2017 | Stainless Watches
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
I need to change the battery of my watch and i don't find the place for removing the back cover
some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
Aug 15, 2011 | Callaway CY2058 Sport Series Watch
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
HOW TO CHANGE BATTERY ON AN OAKLEY BULLET WATCH
Open the watch case back, release the upper contact (unclip or unscrew it), memorize the writings on battery and the way the battery was placed in. Buy exactly the same battery, insert the same way in and close watch case back. Reset the watch and you are done. Some watches need a shortcut to be made before resetting. This should be written on the label covering the battery. Rate me, plz.
Mar 15, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
Battery....can I get a battery replacement anywhere?
Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
Dec 08, 2008 | Skagen Watches
My watch needs a new battery.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Aug 27, 2008 | Fossil Watches
Giorgio Armani Emporio Armani Ar0562 Classic Watch Logo
785 people viewed this question
Top Giorgio Armani Watches Experts
Ansel Alberto
Ansel Alberto
Kolbrun...
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
