Question about Foxconn G31MV-K Motherboard
Foxconn G31MV-K MOB. Of late stopped logging on to internet. Tray icon says limited or no connectivity.Status window shows 142 bytes upload but no download. tried reloading drivers no luck. whazzup.
  • 519 Answers
In order to assist you I need to know exactly how you connect to the internet and who your service provider is. The problem is almost certainly with your ISP (service provider) and not with your PC.
Best wishes,
Graemevm
Posted on Jan 11, 2012
3 Suggested Answers
  • 2567 Answers
SOURCE: Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Posted on Jul 26, 2009
  • 80 Answers
SOURCE: will a pci 2.0 express x16 video card be
yes this board will be compatible
Posted on Feb 27, 2011
EVGA Geforce 8400GS is compatible with FOXCONN G31MV-K Motherboard?
Check your installed ram sticks. (one at a time) the card is compatible with your board But the problem may be with your operating system and not the hardware. on start, press F8 and select "Last known good config" if the system still fails you may have a duff card.
Jul 21, 2012 | Evga GeForce 8400 GS Passive 1024MB DDR3...
I thought that once I installed the Netgear I would have an icon in my system tray showing the strength of the available wireless connection. My computer is running Windows XP. How do I get that icon in...
On each computer that has a wireless connection to the internet through your router you can enable the status icons as follows:
Click on Start and Control Panel.
Verify that Control Panel is in the "Classic Mode"
Double click on "Network Connections"
Right click on your Wireless Network Connection
Click on Properties
At the bottom of the "general Tab" in the Wireless Networks dialog box, place check marks in:
"Show icon in notification are when connected"
"Notify me when this connection has limited or no capability"
Then Click on OK and exit Control Panel.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jan 29, 2011 | NetGear WGR614 Wireless Router
I want to logon to my web but couldn't
You have to be more specific. I assume you're using Vista. The most likely reason for anyone to be unable to log onto a web site is the lack of a connection. Most systems have by default icons on the bottom right corner area of the desktop (called the System Tray). If you see an icon showing a tiny pair of monitors, but no blue globe, that means you may have a network connection, but no connection to the Internet. Right click on this icon and select the Status option from the ensuing menu.
Up pops up a small window telling you whether you're connected, and you should see numbers (of bytes or packets of data) flowing, either under Received or Sent.
Most likely, when there's a hardware problem, or a disconnection of some sort exists, the icon should have a RED cross over it, calling your attention to a problem.
If this is the case, the first thing I would do is check that the ethernet cable is properly inserted and sitting in its socket at both ends: the PC and the router, or wall plate, or what have you.
Next, right click on the icon with the RED cross on it and a menu pops up. Select Network and Sharing Centre. This window depicts graphically your connections. When all is fine you should see your PC with whatever name you gave it, then an icon depicting your network (or routing device) and then a globe representing the Internet.
If only the first one appears, you have a problem with your network card. If the first two appear, but no globe, then you need to reset the connection by clickin on the broken line uniting the components just described. A window appears stating that it's trying to fix the problem.
Most likely, it will be resolved in a minute or two.
If that fails, Windows tells you in a message that it has been unable to correct the problem.
If that is the case, try rebooting your machine, after shutting it down and letting it rest for a couple of minutes.
If all else fails, and if your PC is still under warranty, I would suggest you take your machine back to the store and have them look at it.
Aug 17, 2009 | Dell Computers & Internet
Jul 26, 2009 | Foxconn Computers & Internet
Cannot connect to my Netgear WRG614 v6 Router. My Dell laptop shows an excellent connection but it says limited or no conectivity? I have tried several suggestions and reseting several times...nothing...
If you are using LAN cable from your ISP. Try to connect it to your Computer LAN port directly or how you connect directly your internet connection from your computer without the router. Then on your system tray try to look the internet icon activity usually a two monitor icon. Right click on there. Then select status,then support, then details, from there see the DNS number you may get two DNS numbers set then put that manually to your wireless lan settings.
Jun 06, 2009 | Computers & Internet
Need to change my ip address
there will will be a network status icon in the system tray
Click on the icon bordered in red and a window will be opened showing the status of the connection.
Click on the properties button and a screen showing you the properties of the network connection will be opened.
Under the general tab, there will be an option called , Internet Protocol (TCP/IP). Click on it and select properties. Now u can enter the required IP address.
all the best
Oct 06, 2008 | Computers & Internet
Problem in wireless connection and showing limited access
typing incorrect password weather in wireless setting or in computer
Jan 28, 2008 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Foxconn G31MV-K Motherboard Logo
78 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
