posted by thill180 on May 09, 2008
Ever time I make or answer a phone call it is set to speaker phone. Even when I use the speaker phone button on the left hand side of the screen nothing changes.
Please Help.
3 Other Users Have The Same Problem
Comment by Guest, posted on Jul 15, 2008
Same problem here, there was *no* sound, I powered it off, took out the battery, brought it up again, reset it - and from then on it was on speakerphone whether I selected speakerphone on or off
Comment by Guest, posted on Jul 14, 2008
Same problem here, any help on this would be great.
Comment by Guest, posted on May 27, 2008
Same here. It did fix itself once when I reset it, but the second time it happened I have been unable to get it off loudspeaker. Somewhat infuriating.
Solution #1
posted on Jul 20, 2008
I have been suffering from the same problem.... am not exactly sure as
to what
is happening but after what i observed it tends to happen when u plug
in or plug out the USB handsfree that comes with it. I tried several
things including what you people already mentioned. But there is 1
solution that worked with me. I had reinstalled the O2 firmware on my
phone again which was obtained from the O2 website itself and it
started working fine again. So try it
for yourself. Dont forget to backup your data and remove your memory
card before reinstalling the firmware.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I have been suffering from the same problem.... am not exactly sure as to what
in or plug out the USB handsfree that comes with it. I tried several things including what you people already mentioned. But there is 1 solution that worked with me. I had reinstalled the O2 firmware on my phone again which was obtained from the O2 website itself and it started working fine again. But then the problem did come back again in about two or three days. So what I do is install the firmware again. I agree its stupid thing to do but maybe it works good for you. So try it for yourself. Dont forget to backup your data and remove your memory card before reinstalling the firmware.
Suggest a new solution for this problem
Post a New problem for O2 Xda Orbit Smartphone
Email this problem
Email this problem
Can you Help with these PDAs problems?
O2 XDA Orbit - Mouse Pointer...
Dear Friends, I have o2 xda... Answer This...
LG kg 200 moile signal problem
Dear Sir,i hav bought a LG kg... Answer This...
Repair Service
Find PDA Repairman Near You:
