Question about Asko T701 Electric Dryer
The fuses keep blowing. Eileen Weber - Asko T701 Electric Dryer
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
I want to start by clarifying, is it the 15amp fuse or the hi-limit cutout ( under the black button on rear panel ) as some refer to it as a fuse.
If it is indeed the 15 amp fuses which continually blow, you`ll need to install the part which houses the fuses and the "holder" part which holds it.
You also will need to remove the top and inspect the wiring, especially those coming off the fuse holders.
Over time they burn up due to becoming loose from vibrations and which as a result blow the fuses. The same is true for the hub & holder assembly, metal fatigued due to heat = blown fuses.
You can purchase the complete kit at "repairclinic.com" for about $50 and will look like this...
Let me know how you make out or if I can assist you further.
Thank you for choosing FixYa.
Good luck.
macmarkus :)
Posted on Aug 31, 2010
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Dash gauges not working
Hi Eileen,
Yes you have to inspect fuse board and i think the main fuse is the problem.
regards,
nuwan
Jan 10, 2014 | 2005 Ford Freestyle
Hello I have a Smeg 161s2 built in washing machine, I have a back wash problem and while off the machine fills up with a little water enough to cause an unpleasant odour. I do not think this is normal...
Hi Eileen , there is usually 2 main causes for this type of problem
1. your sink u-bend is starting to clog up ( use a good quality drain cleaner ( mr muscle etc )
2. your sink is syphoning back into the washing machine ( purchase an anti syphon valve from B&Q or homebase/home depot )
hope this helps
Aug 16, 2010 | Smeg Washing Machines
What is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
May 29, 2010 | Weber Genesis E-320 Propane Grill
I need to order a new lid for my weber chill 05-1...
Buy a plastic cutting board. Cut it into a 16 inch circle and put a handle on it. Works better than orginal. Keeps things colder
May 20, 2010 | Weber Chill 05-161 Beverage Cooler
Natural gas grill blows out in wind
Hm. Didn't like the idea of putting duct tape on my brandy new weber but thats what I did to keep the burner lit today in the wind. The 4" open area on the back, covered it with three strips of duct tape. Also stuffed aluminum foil in the right side to somewhat plug that crack. Trying to cook the ribs slowly (low flame on the second burner only which usually gives me about 225 degrees) and its windy as heck today. I surely don't plan to leave the duct tape there. Will probably invent a metal thing that slides up and down to cover that gap.
Apr 02, 2010 | Weber SPIRIT E-210 (NG)
Have a Weber Genesis Silver. Gas is not flowing.
take off the grate[s] and the plate that covers the burner, find where the gas supply goes into the burner - use a compressed air source with a nozzle and blow out the burner and orifice - spiders and sometimes mud daubers love little spaces like this and will build a nest in 'em - even the slightest restriction will cause major headaches
Aug 14, 2009 | Weber Q Grill
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Mar 09, 2009 | Whirlpool LGV4634JQ Gas Dryer
Asko T701 Electric Dryer Logo
352 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
