Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell Pro Heat
My bag that you put the water in rip around the top and I would like to replace it. Where can you get the part for it?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49925&thid=581652
Bissell Pro Heat
posted by saboulis on May 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You have a Bissell 1699 ProHeat Clear View Upright Steam Cleaner and the best thing that I can tell you is to contact some of the companies I will list below. I always check with your local vac cleaner dealer in you area as a suggestion. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 09, 2008
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
Where do i put the water at in bissell pro heat?
The water goes in the funnel area of the water tank. this tank serves to handle both NEW water and dirty water, separated by a plastic bag..... Water only in this area....
Feb 13, 2011 | Bissell Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat - belts are ok. water will not
Remove the handle, disassemble the lower section of the top to get to the heater. Make sure the unit is unplugged! Use miniature bottle brushes like the painters use to clean paint sprayers (I purchased mine from Harbor Freight for about $4) and clean out the ports. Also check the valve that the trigger opens. It is located just above the heater.
Feb 15, 2010 | Bissell 1699 ProHeat Clear View Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
66 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
