Question about Samsung LN46C530 TV
Samsung LN46C530 TV. Have had the TV around 1.5 months. It appears that the remote sensor on the television has stopped working. Both remotes work but the TV doesn't read them. Is there a quick fix for this?
  • 1,512 Answers
G'Day
I have a similar Samsung set... and found that the remote sensor is rather low gain. I noticed the same thing when I first got the set. The remote did not seem to work. Pointing it directly at the right side corner at the power light of the set seemed to allow it to work. 10 degrees away from that either side and it does not work. I also had 2 remotes that behaved in a similar manner(got an additional free 22" set with my purchase). I also suggest changing the batteries out as the ones supplied with the set are generally low brand,and may not last that long.
Other than that, you may need to contact Samsung service to have the set replaced/repaired. Your best point of contact here is the retailer that sold you the set. If they cannot arrange for the repairs for you, let me know where in the world you are, and i will get a contact number for you.
regards robotek
Posted on Aug 31, 2010
  • Samsung Master
  • 3,866 Answers
Quick fix?
Afraid not the issue here if the remote sensor in the tv has died that part/board will need to be replaced. Its not something where a reset will just work.
I mean i hate to Say the word TRY, but unplug it and plug it back in but i am sure the board will need to be replaced at this point if both remotes did not work with the tv/
please update me with any new information you find.
Please be considerate and update this case with your ratings and feedback today, thanks
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
Samsung LN46C530 wont turn on.
Hey Mark,
Samsung's are notorious for bad caps, have you ever opened up the set? There could be other problems but I would start with power supply capacitors. The tops should be flat, look for any that have bulging tops !!!
Jul 23, 2012 | Samsung LN46C530 TV
My remote control stops working every few months or so, then starts working again. My warranty goes out this month. Just have a service call and the tech left me another remote, but I'm afraid this will...
The remote interface of the TV died on mine, it was intermittent then it stopped completely. Remote control is fine, it's the remote sensor in the TV itself.
Mar 09, 2011 | LG 50PC3D 50 in. Plasma Television
We have an AK59-00104R remote for our Blu-Ray player and a Samsung TV. The remote has been working fine on both for over a month now and yesterday it stopped working for the TV. I'm thinking my 1 year old...
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Jan 25, 2011 | Samsung AK59-00104R Remote Control
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Remote No Longer Works
It appears the remote sensor in the Television itself has stopped working. If the TV is still under warranty I would try to contact the manufacturer to see what they can do for you. Can you still change channels manually? If so, this is most likely the case.
Dec 29, 2007 | Philips Magnavox 27MS343S 27" TV
Remote Not working
hi there, check up the sensor, do some cleaning, check up for some cold solder, do some test and check up. ty
Nov 27, 2007 | Sharp 32U-F510 32" TV
Remote Sensor
I heard that LG TVs have a problem with the TV not responding to the remote control (there is nothing wrong with the remote control). Hopefully your TV is still under the 2 year warranty. Go to LGService.com and report the problem. They told me that it's a common problem. They need to order the part and let me know when it comes in. (my TV is a LG 50PC1DRA)
The Akai TV might have LG guts inside.
Oct 14, 2007 | LG 42PC1R 42 in. Plasma HDTV
TV doesn't recognize any remote
The proble is the IR sensor 932220681667 or the small signal board. I would replace the IR sensor first. Also check the firmware and make sure it is BX23U-1.5.0.0_03531 and if it is not go to www.usasupport.com and down load the firware on a USB stick. If the set still has the problem when both are done replace the small signal board.
Jun 17, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung LN46C530 TV Logo
745 people viewed this question
Jerry Greenberg
Jerry Greenberg
