Question about Logitech X-530 Computer Speakers
I have a Logitech suround sound computer system i want to re wire it for home theatre so i need to know the positive and negative wiring
  • 40 Answers
You are at the x-530 section,if that is the one, you have here the instruction manual. If not,go to www.logitech.com and search for your model`s instruction manual
Posted on Dec 24, 2010
Logitech z-506 computer speakers not working
Have you got the 3.5 mm plug in the sound out it could be in the mic hole.
Aug 29, 2014 | Logitech Z 506 - Pc Multimedia Home...
Panasonic SC-HT730 home theatre has no centre or surround audio. Front right and left work, nothing else. What could it be?
First thing is to check the wiring. a simple flipping of the positive and negative at the back of the theater box can fix this. I know they have the color coded wires and suppose to be plug and play but I see these reversed all the time right from the factory. If that does not work repost and I will follow up.
Nov 12, 2012 | Panasonic SC-HT730 System
I have a panasonic home theatre model sa-ht900. everything plays fine but i have absolutely no sound at all.possible solutions?
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
≥Check the connections.
≥Turn the volume up.
≥Turn muting off.
≥Switch off the unit, determine and correct the cause, then switch the unit on.
Causes include:
-Shorting (bare wires touching) of positive and negative speaker wires.
-Using speakers with an impedance lower than that rated for this unit.
-Straining of the speakers through excessive volume or power.
-Using the unit in a hot environment without proper ventilation.
Jan 30, 2011 | Panasonic Home Theater System System
I have an ULTRA LINEAR HOME THEATRE SUBWOOFER + 5.1 SURROUND SOUND system i am having trouble connecting the subwoofer on the back of the subwoofer it has 4 sets of positives and negatives and i can't seem...
You should have received a MANUAL with the system. Although the RED/WHITE/Black wires relate to Positive or Negative connections, the power is low level audio which is not powerful or dangerous. If you plug any line into another port, it will not damage the system, so try to switch lines around until you get the system working. Naturally you need to place RED out to RED in and so forth; but what ever works is most important.
Feb 03, 2018 | Audio Players & Recorders
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
Can't wire up to LG plasma HELP
Ah, I assume you have put rca's from the TV audio out to the Audio in of the Theatre System! Then put the Audio System to Aux 1 / 2 and you should have sound through your Theatre System!
Feb 20, 2008 | Sony DAV-S500 System
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
121 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
