Question about Garmin Nuvi 660 GPS Receiver
No satellite signals. The system showed "Acquiring Satellite" all the time. Currently I am in New York, but the GPS showed that I am still in boston.
  • Garmin Master
  • 2,130 Answers
Common problem. Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Sep 03, 2010
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
Acquiring satellites
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
I am not getting satalite signal on my tom tom xl
The most common problem to this is because the TomTom doesn't know it's current location.  It may be that you last used your device a long distance from where you currently are now.  I don't know how long you waited for the gps signal to acquire but it can take up to 10 minutes (even on military aircraft if they don't know current location).
Power it up and press on the signal strength icon.  That will bring up your satellite tracking status.  If it don't look like it's doing anything, then your gps has probably malfunctioned.  If it looks like it's acquiring satellites, then give it a good amount of time (10-15 minutes) to see if it can find your location.  I recommend doing it outside of your vehicle with no satellite obstructions to make the process go faster.
Good Luck
Jun 10, 2009 | Tomtom One XL GPS Receiver
Cannot locate saltellite or Acquiring satellite
The error means it can't pick up valid GPS signals. In other words, bad reception.
Has the unit ever worked? Does the unit have an internal or external antenna? Are the batteries fully charged?
Try the unit outside with clear view of sky instead of in the car. This will give it the best chance of picking up a GPS signal.
If it still doesn't then suggest something broken inside.
May 20, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Jan 02, 2008 | Garmin 60 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
