Question about Sanyo PLC XF45 Multimedia Projector
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my screen. other proj fine. whats causing yellow spot?
    Problem Solver:
  • 35 Answers
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Posted on Sep 02, 2010
Viewsonic pjd6531w projector flickers
Look to the color wheel for your problem. They do wear out.
Dec 13, 2013 | ViewSonic PJD6531W Projector
Our church projector model PLC-X456 and serial G4YO4536 shuts off occasionally. I replaced the bulb but it shut down again (during services). Someone mentioned that they did not hear the fan running. I...
If your church recently purchased it, it would be better to refund your money or get a replacement. Its somewhat difficult to find parts for projectors, and when you do, its usually cheaper to replace the whole unit.
Jan 26, 2011 | Sanyo PLCXU350 LCD Projector
Optoma EP719 settings?Colorwheel? Bulb?? Cable?
take the lamp out and shake the projector gently and tilt it in all directions and listen for something loose near the front of the projector. if you hear something it could be the light tunnel has collasped or the colowheel has lost its segments.
May 21, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Sep 19, 2009 | Panasonic Office Equipment & Supplies
It makes a wierd noise
The bulb housing has come loose...
When the bulb heats up & cools in normal use, the housing will contract and become loose.
Unplug and re-seat the bulb and housing ...
Another possibility: If the replaced bulb shattered in the projector, there may be debris in the fan... use compressed air ($8/can RadioShack) to clean out (make sure the projector / bulb are cool before using compressed air.
Hope this helps!
Sep 09, 2009 | InFocus ScreenPlay 4805 Multimedia...
Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Lamp does not come on
For the time being at least, I got my projector back on by unplugging the power cord for about 30 seconds then held down the following keys on the projector: Menu, Enter and the Down Arrow and while holding them down, pressed the power key. The projector started up like new with H0000 hrs on the screen like it was a new one. Will be interesting to see how long the bulb lasts! I had been getting a Replace Bulb messge for several weeks before it shut off with two red lights lit. So I tried the above procedure befoer buying a new bulb.
Aug 02, 2009 | Sharp XR10XL DLP Projector
Shuts Down on its own.
electronis shut down most often when the are over heating.. so if its shutting down it has overheated.
it may be full of dust on the inside.
i suggest 1st taking it down and using a can of compressed air to blow the dust out. iif this doesnt work take it to a repair shop
Apr 27, 2009 | Televison & Video
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Sanyo PLC XF45 Multimedia Projector Logo
706 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
