Question about Health & Beauty
Working on fortress 2000FS scooter, installed two new batteries and when key is inserted alarm stays on until units brake is engaged
2 Suggested Answers
  • 177 Answers
SOURCE: 1700 Fortress Scooter won't go forward or
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Posted on Jun 08, 2010
Pride Celebrity x. Batteries drain quickly despite new full charged batteries. When scooter is pushed in freewheel- brakes engage every few feet. Have to turn scooter on/off to get brakes to release.
hi Diane, the brake engaging is by design, distance is the key here
Have you tried another charger ?
1. when pushing the scooter in freewheel before the brake engages , is it easy to push ? what can happen is the brake does not release 100%, a easy test is to run the scooter then put your hand on the brake unit , is it hot ? be careful because it could be very hot , this will prove the brake is not releasing fully.
Regards
Rob
Dec 09, 2015 | Pride Health & Beauty
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
This problem is on my Pride Mobility Scooter/Wheelchair. I am trying to figure how to keep from having to turn my key off and back on to free up my brakes after they stay sticking after I come to a co
I am not familiar with this but it sounds like a problem in the control module or one of the sensors. You may want to take it to the dealer to get checked out.
Nov 28, 2014 | Pride Health & Beauty
Why does my fortress scooter beel when key is in
I had an old 3 wheel Fortress 2000 a couple years ago.
On mine, iIf the lever at the back (go-nogo) is in the neutral position
(drive not engaged) the buzzer would beep. Go to the back
and move the lever, so the drive is engaged.
Nov 02, 2014 | Health & Beauty
Fortress scooter
Possible faulty brake.
Aug 29, 2014 | Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
Apr 16, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
WHEN I TURN ON MY SCOOTER IT START BEEPING AND THE\r\nLIGHTS ARE FLASHING
There is a yellow nob under the seat ,next to that nob there should be a picture that shows push up for lock and push down to unlock...
First make sure that you have the scooter off
Second make sure that the yellow nob is in the lock position
Third turn the key on that should cure the beeping ...
This happens alot ,when your brake is of the scooter will beep,letting you know the brake needs to be engaged .
Hope I was of some help ,Good luck
Jan 17, 2011 | Shoprider Echo 3 Wheel Scooter
Health & Beauty Logo
80 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
