Question about Cameras
When i turn my camera on the lens doesnt come out
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
I dropped my fujifilm finepix av100, the lens is now stuck and will not go back in when i turn off my camera. when i turn on my camera it says ''turn camera on and off'' but it doesnt solve the proble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
Nov 17, 2011 | FUJIFILM FinePix AV100 Digital Camera
Lens stuck
The slide motor start malfunction, You have to replace complete lens block assembly.
Thanks for using fixya.
Jun 16, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Lens error, so camera isnt' working at all.
Have to replace lense barrel. You can buy parts on e-bay if you like to fix it yourself or check out the repair services there.
Apr 18, 2009 | Kodak Easyshare M753 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
My camera {nikon coolpix l3}
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 24, 2008 | Nikon COOLPIX S200 Digital Camera
My lens is having problems
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 23, 2008 | HP Photosmart M525 Digital Camera
Lens/zoom wont come out
The lens mechanism inside of the lens unit is damaged. The fix is to change the lens. You can send the camera to authorized service rep for an estimate. I believe that the cost of service many be close to or even more expensive than replacing the camera.
Jerry G.
Jul 03, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
