Question about Craftsman Garden
My craftsman pull cord broke on my weedwacker
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck
Posted on Aug 31, 2010
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
Why when I pull the cord, the trimmer doesnot turn
Will not turn if it is clutch driven. When motor starts and revs are up it will turn provided the clutch is working correctly.
Aug 30, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
Grass trimmer pull cord has frozen in the out position
oops jerked too hard or too far . give it a semi gentle thump and see if it retracts
Apr 13, 2015 | Craftsman 27cc 2-Cycle Curved Shaft...
No spark
To test the spark you will need a spark plug tester. Put one end of the tester on the spark plug and the other in the plug wire. Pull the cord and see if fire is there. If not you will need to replace the coil.
Jun 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
How do you change the pull cord on Craftsman P2 Weedwacker Gas Trimmer?
remove the housing that holds the recoil and whined up the spool and thread in a new rope
Apr 08, 2012 | Garden
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Garden Logo
288 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
