Question about Kyocera FS-5025N Laser Printer
Kyocera FS 5025N error code 7001: 0037608 what does this mean and how do I fix it? Many thanks Bri
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
install new firmware
Posted on Dec 18, 2007
Benimur
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
  • 300 Answers
SOURCE: I have a Kyocera c5020n
This what it means (7001 is the error code: 0020988 is the page count) -
Toner motor 4 overcurrent detection
error (black toner)
• The engine controller PWB (KP-1054)
detected the overcurrent of toner
motor 4.
Defective toner
motor 4.
Posted on Jun 16, 2008
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
Aug 01, 2014 | Kyocera Office Equipment & Supplies
Im having a serious issue tring to get my kyocera fs-c5030n to print. I try to print, and it doesnt prompt for a password, but all that comes out if the printer is invalid account id everything I try to...
1. Click Start > Printers and Faxes
2. Right click the Kyocera printer and select properties
3. Select the "Device Settings" tab
4. Click "User"
5. Enter your User Name and Department Code
6. Click OK, OK
If you don't know the User Name and Department Code, these can be programmed by using the "KMNet Viewer" software utility, you can download it from here:
http://www.kyocerasupport.co.uk/index/download_center.false.driver.FSC5025N._.EN.html#
May 04, 2011 | Kyocera FS-5025N Laser Printer
C5025N SERVICE CODE 7001 AFTER CHANGING BLACK TONER
That is a Toner motor K error: Over-current at toner motor K is detected for 80 ms in total while toner motor K is ON.
It may be caused by Defective drive transmission system of the toner motor K.
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
If this does not help, please replace the toner motor K
Mar 17, 2011 | Kyocera FS-5025N Laser Printer
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera FS6950dn shows paper jam but no jam present, does it from any tray.
take out all the trays... take out drum... developer.... fuser.... toner... and look around inside with a flashlight... its in there but its in real far....
May 18, 2009 | Kyocera FS-5025N Laser Printer
HI My Kyocera FS-6020 comes up with the call service number 4200:0019564 number! does anyone know what this means thanks
This error code means that the Laser unit in the machine has failed and will need to be replaced.
Mar 24, 2009 | Kyocera FS-2000D Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Feb 29, 2008 | Kyocera FS-C5030N Led Printer
Kyocera FS-5025N Laser Printer Logo
423 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
