Question about Whirlpool Duet GHW9150P Front Load Washer
My washer door will not open. When I press the Open Door/ Cancel button a buzzing sound will come from behine the handle but the door will not open.
  • 2,272 Answers
First of all try the reset procedure and see if it helps before proceeding towards troubleshooting:-- Close door
Turn machine on------
Select "Drain/Spin"------
Select "No Spin"------
Press the "Options" button 4 times------
There is a short circuit in the door switch assembly.Its not getting opened due to short in the door switch assembly.You need to get the door switch assembly replaced.But before that open the door by screw driver manually then remove the door lock connections and check the voltage at the door lock switch if its check ok then the door switch is faulty and needs to be replaced.But if the connections checked short then its a short in wires not the switch. Most likely the problem is a bad door lock which has to be replaced. You can find the complete instructions in the Service manual.
- The part number for the lock assembly is AP3837611
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 31, 2010
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
Door locked.... tried to unplug and cancel button - still not open??
Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Jan 05, 2008 | Dryers
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
