Question about Craftsman 22" Gas Hedge Trimmer
Flywheel is loose and wont engage - Craftsman 22" Gas Hedge Trimmer
2002 mazda 626 new starter wont engage flywheel. it sounds like starter is spining wont engage flywheel
Couple possibilities. Was the starter just replaced? If so. Were their any shims (small metal pieces) that were not put back? They space the starter so the bendix and gear can align with fly wheel.. secondly could be a bad starter, broke bendix. Bad gear..or third missing teeth on either fly wheel or starter..
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Oct 28, 2017 | Mazda Cars & Trucks
Installed new starter a week ago , now the starter is turning but not engaging flywheel
Check cable nut for loose or dirty. Check voltage with key turn to start,
Jun 07, 2016 | Garden
I have replaced solenoid and starter and still starter makes noise but doesent engage the flywheel why
Sometimes the starter has to be shimmed to engage the ring gear of the flywheel
Mar 17, 2013 | Cars & Trucks
Starter wont engage
either the starter is not kicking out its gear to meet the flywheel or the flywheel has missing teeth. either way the next step is to remove the starter so it can be tested outside of the vehicle and the flywheel can be looked at through the hole where the starter sat.
Mar 05, 2013 | 1987 Ford Ranger
1984 Ford Ranger Starter replaced but won't engage flywheel
it sounds like it need a shim to mount it up. not sure where you can get one though. maybe make it. search starter shims to see what i mean
Nov 30, 2017 | 1984 Ford Ranger
Starter is running but wont engage flywheel
check the starter gear, maybe it didnt actuate.
May 10, 2012 | 2001 Buick LeSabre
Wont start
starter cog is spinning and not engaging in flywheel , take out starter check for burr on cog .
Mar 22, 2012 | 1996 Jeep Grand Cherokee
My 95 eagle talon tsi wont start replaced the batery. stater doesnt engage
Be sure the connectors at d battery are ok. Check for broken, loose or disconnected wiring @ the starting unit, check neutral start switch, ignition switch n starter solenoid. If all these are eliminated, it might be that the starter motor pinion is jammed in flywheel ring gear.
Sep 28, 2011 | Cars & Trucks
Turn switch on and all the lights work but the starter wont engage
If the starter wont turn...Id check / replace starter solonoid.
If the starter turns but doesn't engage the flywheel...I'd check / replace the bendix.
If starter checks good and bendix is good...I'd look at the teeth on the flywheel.
Hope this helps...
Jul 23, 2011 | 2005 Jeep Wrangler
Craftsman 22" Gas Hedge Trimmer Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
