Question about Jenn-Air JMC7000 Microwave Oven
JMC7000ADW Blows circuit breaker
I have a Jenn-Air JMC7000ADW Microwave / Oven in wall combo that is 8 years old, Blows circuit breaker when you push the open button at times, have replaced Diode, still blows breaker (at times)
  • wally1947 May 09, 2008
    Yes, I have to keep replacing fuse in unit
  • JHughis Apr 03, 2009
    the first time the primary switch welded shut in the NO position so I relpaced all 4 switches and while I had it open I also replaced Capacitor, Rectifier, put it back together worked great for a week or so it blew the fuse again after that week I opened it back up and the same switch welded shut in the NO position again I wrote it off as a defective switch so I replaced it again worked great again for about a week.. the switch did it again welded in the NO position (that makes 3 times) the magnatron was replaced about 1 yr ago what else can it be. if you tell me the transformer please tell me there is a after market transformer I dont want to buy it from sears they want to much for it. if its not the transformer than please tell me what else to look for I do see in tracing the wires back that they do at some point lead back to the transformer
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
  • k9yjy Nov 16, 2008
    For JHughis. The switch that k9yjy changed was the Upper Primary switch. I bought it at my local appliance shop for less than three dollars. It is a bit difficlt to get out, but patience and you will succeed. There are a couple of screws holding in the switch bracket and two wires attach to the switch that can be carefully pulled off the swithch with a pair of small needle pliers. Unfortunately one of the the push on connectors on my microwave had overheated and had to be replaced. The appliance shop didn't have a connector, but I found a suitable substitute at my local auto parts house. The switch has two holes in it and it fits over a plastic nub sticking out of the plastic bracket.
    There are some plastic cams attached to the door that activate the switches so be sure to watch how they are mounted and get them back in the right place when the switch bracket is removed to access the switch. After replacing the switch open and close the door a few times to be sure the cams are actuating the switches properly. If you have a digital camera you may wish to take a close up photo of how the switches and cams are mounted. For those with intermittent blowing of fuses when the door is opened you may wish to change this switch first since I found my switch stuck closed once in a while as noted in my original solution and that would blow the fuse.
    For safety - be sure to turn off power to the microwave and unplug it from the power source. Because components for the high voltge could possibly retain voltage be careful when working around the power supply components inside the microwave.
    Problem Solver:
Do you know which switch it would be Primary or secondary?
Posted on Oct 27, 2008
Only fuze are replaced
Posted on May 09, 2008
Microwave in Jenn Air Microwave/oven combo is not heating at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 07, 2009 | Jenn-Air M170 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
JennAir JMC7000ADW Microwave Oven Not Heating Well
Assuming the turntable is working and the power at the outlet is correct (110 to 125VAC) then you almost certainly have a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first: http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 22, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
No power on Jenn-Air JMC 7000 ADB Microwave
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Oven and microwave combo
Fuses and circuit breakers imediately come to mind as the first things to check.
Oct 28, 2006 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
821 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
