Question about Health & Beauty
Users manual for a Quinton Q4500 stress system (not the treadmill)
  • 13 Answers
SOURCE: I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Posted on Aug 10, 2009
SOURCE: I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Posted on Nov 24, 2009
SOURCE: owners manual for Quinton 510 treadmill
what manual would best guide me in using the 575 crosstrainer treadmill.
Posted on Feb 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a quinton clubtrack treadmill with an E105
E105 means power interruption if this is a 3.0 or Hyper Drive just need to hit clear or start that should take of code until either it is unplugged another power outage
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: Users Manual for Weslo exercycles
Go to www.iconservice.com input manufacturer then brand name you will find a manual for your unit.
Posted on May 06, 2010
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
Tip
How To Calibrate the Lift Motor on Quinton ClubTrack Treadmill
The following describes the steps required to calibrate the lift motor on a Stairmaster (Quinton) ClubTrack.
  1. Enter service mode on the treadmill by using the following keys at the same time:
    • Faster - Slower - Stop Belt
  2. Allow the lift motor to free spin by removing the bolts from the metal block on the jack screw.
  3. Press the up arrow on the control panel until the incline is at 5% then press the down arrow and take it back down to 0%. This will allow the lift motor rheostat to find its range.
  4. Spin the metal block on the jackscrew to allow 1 - 1.5 threads to be exposed from the top. Secure the lift motor back to the frame by inserting the 2 bolts through the bracket holes and into the metal block. NOTE: Double check the spacers on each side to make sure they are flush.
  5. Run the treadmill incline up to 15% and check the jackscrew to verify it has not bottomed out before reaching 15%. There should be around 4 - 6 threads exposed. Bring the treadmill back to 0% where there should be the same amount of threads exposed from the top of the jackscrew. If you see the correct amount of threads the lift motor is calibrated.
NOTE: If there is an error on the display panel, ex. E211, you need to manually turn the jackscrew back to 0%. To perform this unscrew the 2 bolts from the bracket securing the metal box and jackscrew allowing it to freespin. Use a shop rag or towel to wrap around the jackscrew to prevent damage to the threads. Using a pair of pliers (channel locks or vice grips recommended) manually turn the jackscrew back to 0%. Once this is accomplished run through the above steps to perform the calibration.
Quinton Treadmill Support How To Calibrate the Lift Motor
on Mar 10, 2015 | Quinton CLUB TRACK Treadmill
Quinton treadmill error 203
5. Motor.
Jun 16, 2012 | Exercise & Fitness
Stairmaster quinton 612 plus error code e201
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Corrective Action
Mar 16, 2012 | Exercise & Fitness
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
Owners manual for Quinton 510 treadmill
Dec 08, 2009 | Exercise & Fitness
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Jun 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Health & Beauty Logo
346 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
