Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Water is leaking out of bottom vent inside freezer and pooling and then freezing on bottom of freezer under pull-out storage unit.
  • 2,382 Answers
Hi, it sounds like drain iced up in freezer section. if you can turn cab off, remove back panel inside freezer section, allow ice in drain to thaw, use hairdryer to speed up defrosting, be careful, water and electricity dont mix. Usual cause is partially blocked drain hole. Also check the following, if drain area has a seperate defrost heater make sure it is working and if self adhesive foil type it should be in good condition and in good contact with drain pan. At the back of cab check drain hose for holes and splits and ensure good drain trap and/or correct operation of drain non return valve.
Posted on Aug 31, 2010
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
Water is leaking out of inside bottom vent of freezer and pooling and freezing on bottom under pull-out container unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
