Question about Casio EV-1000 10.4 in. LCD Television
Do you know what is the code for direct tv box -Dolby digital.
  • Casio Master
  • 11,800 Answers
Your tv isn't officially supported - there is no specific Casio code stored in the remote. The only thing you can do is to perform a code scan, maybe the code for another tv will match yours.
Posted on Aug 31, 2010
Audio not passing through hdmi
Make sure on your source devices that you have dolby digital turned on for example direct tv boxes come with dolby digital turned off by default. There is also in the setup of the receiver a area where you can assign audio inputs so you will have to check to make sure it matches up to the hdmi source you are using
Dec 18, 2013 | Denon AVR1912
Ge universal remote codes for a Dolby digital converter box
I have a Dolby Digital Analog TV converter box, however i cannot successfully activate it.
Because it was given to me as a gift, yet there was a V Chip Password that was set. I cannot retrieve that password.
What are my options? Thank you
Jul 24, 2012 | Televison & Video
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Nov 16, 2008 | Onkyo TX-DS575 Receiver
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Casio EV-1000 10.4 in. LCD Television Logo
78 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
