Question about Oxo Porcelain Pedestal Bathroom Sink, Italian Design, New #3004
I have a very old yellow porceline sink. How can I make it look newer? Faded yellow and no shine.
  • 490 Answers
Howdy, if you are attached to that sink ( I understand) and replacing is out of the question, then there are two coating methods available; one is to use a two part home kit which I cannot recommend, and the other is to have it professionally recoated (expensive, permanent and perfect). Your local plumbing contractor will know who in your area does this service. If you like, tell us your area, and we will find one for you. Hope you find this helpful.
regards,
Farmerbear
Posted on Aug 31, 2010
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Tip
Re-birthing a Tail Light Lens.
Faded plastic lenses are dangerous and illegal. To re-juvenate faded or sun bleached lenses, a polish can achieve remarkable results, rather than the expense of a new one. Any cream polish or finishing auto paint cutters will work. Use a cotton rag and work in small circles, you will see it shine up beneath your fingers. DO NOT USE anything with an evaporative solvent such as Brasso or silver polish, as the solvent will etch into the plastic and the rag will stick like superglue to the lens. The lens below is from a 20 year old DR650RS parked in the Australian sun.f88686b.jpg
on Jun 10, 2010 | Motorcycles
Using the contol buttons on front panel
You did not give a lot of info in this.
was the monitor old (many year) did it happen slowly or not.
is it even on all surfaced or darker on one side?
faded : no contrast or darker?
From the point vue I get, seem to be the neon lamp one maybe shot or not working a 100%
with year, the neon lamp loose brightnest. they even get yellow a little bit (if you compare a new monitor with an old one (white area) the old always fade in the yellow. )
Jan 03, 2014 | Dell Computers & Internet
Faded plastic on a fourwheeler can the shine come back
First you should wash it clearly and dry it in hot air then rub it by a dry clean cotton
Sep 29, 2013 | ATVs
Can faded plastic get its shine back on a fourwheeler
It is possible if it is not too far gone. If the plastic is severely faded, the chances lessen. There are several different types of restorative products that you could use, and they can be found at almost any auto parts store.
I hope that you have found this information to be useful, and if I can be of any further assistance, please let me know. Thank you for using fixya!
Sep 29, 2013 | ATVs
My one piece original porcelain sink and counter has an uneven hole where the stopper is to go; the new faucet I am installing will not sit evenly and leaks! HELP - how can I even out the sink or get the...
If it is truly a porcelin top then you can use a product called plumbers putty available at your local hardware store. It will conform to the shape of the drain and provide a good seal. If this is a cast marble or resin type of product then plumbers putty will void any warranty and possibly discolor the sink. Ensure it is indeed porcelin before continuing and follow the manufacturers directions for installation. Good luck with your project.
Jul 13, 2010 | American Standard Home
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
Reset button on TDA 03211c
I'm not aware of any reset buttons on the newer sets, some plasma sets have one but it's only for re-setting default settings.What type of problem are you having?
Mar 04, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Jan 28, 2009 | Home
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Oxo Porcelain Pedestal Bathroom Sink, Italian Design, New #3004 Logo
73 people viewed this question
Top Oxo Home Experts
Donni Steen
ray gallant
Are you an Oxo Home Expert? Answer questions, earn points and help others
