I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with HDMI - try to connect to TV with the same issue. Tried 2 different HDMI cables too. Help
  • bucko3030 May 11, 2008
    Thanks for that and have now fixed it. Realised that although my TV has the HDMI connection, that it cannot accept digital audio - all the TV was telling me was that it could display the high res video but not support the sound which i feed through my AVR anyway. The issue with the STB was that i had the incorrect screen resolution selected - as soon as i changed it to 1080, it was fine. Thanks for your help though.
  • 34 Answers
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
Posted on May 10, 2008
Not receiving a TV signal through the DVD recorder and cannot record programs or watch TV through the DVD recorder
Firstly you must have a good connection from your antennae to the dvd recorder, secondly a good connection between recorder and tv
via scart lead or hdmi. Check these out before you do anything else.
Mar 21, 2014 | Panasonic Dmr-XW380 Dvd Recorder
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
My problem is that i have a 56" philips with hdmi etc... i have my dvd recorder plugged in via audio video cable .... i have my cable coming thru hdmi... i cant get my recoreder to record whats...
Hello rpgscope,
I am assuming both your dvd recorder and cable is plugged into your tv? Conncet a composite cable (rca cable or aka red, white, and yellow cable) from cable box OUT to dvd recorder IN. That should fix the problem. I mention composite cable but if you another slot for av then go ahead and use that. Make sure you have AV connected from dvd recorder OUT to the tv IN. Also the cable box should be HDMI OUT to tv IN. If you have it connected like this, it should work. Hope this helps.
- Joe
Aug 30, 2011 | Toshiba Televison & Video
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
