Gurgling noise coming from unit, like it's drowning! Sharp Comfort Touch Room A/C unit AF-P80CX
    President:
  • 3,773 Answers
Make sure the drain in back is open and the floor of the unit is clear from front to back and that the unit is tilted backwards
slightly
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Testimonial: "Answer was helpful, even though I have no idea HOW to check the drain..."
Sharp AF-S100FX Comfort Touch Air Conditioner not working
You may have it in a timed mode. Here are the instructions for your unit. There will be a start delay if it is in timed mode. My Retrevo My Manuals
May 15, 2014 | Sharp Comfort Touch AF-R120EX Air...
My air is driping water inside
That's condensation; it's the humidity begin removed from your room. It's totally normal and you actually want it. Just make sure to tip the AC a little downward on the outside so that it can drip outside.
Aug 08, 2011 | Sharp AF-S120FX Comfort Touch Air...
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
No power to my wall sleeve air conditioning unit. Outlet has power.
its very common with all the vibration within the wall unit for wires to come loose try tighting all wires if this does not work call a tech it should simply be a loose cable ..very common
Jun 24, 2010 | Sharp Comfort Touch AF-R120EX Air...
My sharp comfort touch air conditioner make loud noise from fan. It is very loud. I have 2 and both are very loud. I took the unit out of the wall to inspect, and could find nothing obstructing the fan.
Hi, you may want to check the bearings on the fan motor it self. They will wear or get dry and make very loud noises. Check the motor body at each end to see if this motor has oil caps at each end to add a few drops of oil. Some motors do and other motors have sealed bearings and when they go, there is not much you can do when they fail. If it does have a place to oil them, get the oiler at a hardware store. They come in a small plastic bottles that telescope to reach the bearings. This may take the noise away if the bearings are not already gone. Let me no what you find and we can go from there. I wish you the best,
Shastalaker7
Jun 19, 2010 | Sharp Comfort Touch AF-R120EX Air...
Thermastat is reading colder than the actual temperature of the room
Your question is phrased a little odd.
1) If when you say 'thermostat' - you are actually talking about a 'temperature reading' on your thermostat - then I would tell you to just get another temp measuring device and double-check the temp.
2) if howerver you are talking about the set-point of your thermostat - for example - you might have it set on 70 degrees and the room temperature is 78 - then I would say that the AC is not big enough to pull the temp down to 70 in the room, or, you have a problem with the AC that does not allow the unit to pull the temp down.
good luck!
May 02, 2010 | Sharp AF-S120FX Comfort Touch Air...
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
