Lg plasma blue light flashing - Televison & Video
4 Suggested Answers
  • 197 Answers
SOURCE: flashing blue light error code reset?
bad main pcb
Posted on Jun 07, 2009
  • 8457 Answers
SOURCE: LG plasma just turned off for no reason,
Try unplug,replug for reset that all could do,same prob.must change tha Main backlight Vivdeo board.
Posted on Nov 17, 2009
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
My LG Plasma 60" 60PG60 TV refuse to turn on. Red button light comes on but the blue light flashes and turns off. No picture, no sound. Please Help.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 25, 2016 | LG 60PG60 60 in. Plasma HDTV
50" lg plasma tv will not power up
The problem with the set is bulged electrolytic capacitors in the power supply.
May 16, 2010 | LG 42PX5D 42 in. Plasma HDTV
I can't turn on my 32 inch plasma tv by LG.A green light flashes twice on the power indicator than turns red.
The flashing indicator is telling you the fault. Give the number of flashes to the LG service department and they can help you with your issue. It will likely need service.
Mar 30, 2010 | LG 42PC3D 42 in. Plasma Television
LG plasma just turned off for no reason, try to turn back on , but blue light(on) flashes for 2 seconds, then turns red(standby)
Nov 17, 2009 | LG 50PG20 50 in. Plasma HDTV
Horizontal flashing color stripes.1/2 second intervals on pic
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
Televison & Video Logo
294 people viewed this question
Top Televison & Video Experts
Electro Med Services...
