Question about Kodak EasyShare LS443 Digital Camera
Pls solve my problem
My camera is showing E45 on the screen
    Champion:
  • 203 Answers
Kodak simply states camera requires service or repair for e45
Posted on May 09, 2008
Not a camera question E45 on tv screen switch on tv it says 'E45 Service not Aurhorised' won't let me in to any channels
E45 means Service not authorized indicating that an attempt is made to tune to a transport stream which is blocked. In this case, remove the smartcard, rescan all networks before reinserting the smartcard. Also check that you are using the current version of the software on your decoder. DSTV ERROR CODES MEANING AND SOLUTIONS
Feb 13, 2017 | Cameras
Kodak EasyShareLS753 screen has camera Error #E45 what is problem and how do I fix...turn the camera off and then on. if you encounter the same error, go to
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
May 09, 2011 | Kodak EasyShare LS753 Digital Camera
When you put on the camera, the light in the top left hand corner flashes red for 9 seconds. then the screen shows error e45, then cuts off
The firmware must be damaged. Search in your product manufacturer website for you camera model and try to firnd how to update it.
Mar 01, 2011 | Cameras
Error e45
Kodak indicates that the e45 error means that it's time to repair your camera.
But, it could be that your battery no longer has the capacity to adequately power the camera, especially the lens function. Lithium Ion batteries lose capacity over time. If your battery is over 3 years old, a simply replacing the battery may solve the problem.
Nov 15, 2010 | Kodak EasyShare V705 Digital Camera
How to fix error E45 on a Kodak V570? my camera stop functioning and only "Camera error E45" on the screen, all buttons and do not respond, only on/off button is working.
The bad news is that this error means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera.
Thank you !!
Jul 28, 2010 | Kodak EasyShare V570 Digital Camera
Mine is sony handycam; when I try to record, screen shows nothing
the cable connecting the ccd to the processing board could be loosened or removed. camera has to be opened to solve it.
pls check the iris whether it is opened properly before opening the camera.
Jan 03, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
E45 Error
turn the camera off and then on. if you encounter the same error, go to www.kodak.com/go/itg to either avail of the service upgrade program or get it repaired.
Apr 11, 2009 | Kodak EasyShare LS753 Digital Camera
Camera error # e45
http://www.digitalcamera-hq.com/digital-cameras/kodak-easyshare-ls443_question.html?qid=5943
Try your luck
I bought one yesterday new for 25 $, so ...............
Bit more plastic then the previous Kodak but 10+ megapixel and video and moving shot ok.
Rate me for a good advice
Nov 19, 2008 | Kodak EasyShare V530 Digital Camera
Screen says error#e45
mine says the same thing can anyone help? manzanero26 is my y
Jun 04, 2008 | Kodak EasyShare LS753 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
