Question about Canon imageRUNNER 5020i Copier
From where do you remove the waste toner bottle and replace it with a new one?
  • 62 Answers
Right hand side of machine towards the rear lower small cover two screws at top to remove. Remove bottle empty into plastic bag with no holes in the bottom,then replace old container. Tie the bag off and try not to inhale the powder it is not good for you.
Posted on Sep 17, 2010
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
Jul 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
How do i empty the used toner?
WAIT!!! Don't let Ricoh Steal your money...
You're going to get a little bit dirt with the trick, but there is no need to buy a empty waste toner bottel
Empty the waste toner bottle inside a plastic bag, the dust is kind of azard!!!, when the bottle is empty, clean it from the outside.
Place the bottle in the printer, (This is just for reference only), in the right side of the bottle you're going to see a plastic tag all dirty (You see it?) OK!!, remove the bottle from the printer, and then very carfully remove that plastic tag from the bottle taking care of not ripping it off, now clean the plastic tag, and put it in place again, and now your printer is ready to work!!!!!
Where's the trick?, The printer has a Photo sensor that is "looking" trugh this plastic tag, when the plastic tag is full of toner, the sensor can't get the signal, and then it says that the waste bottle is full..!!!
TONY!!
Feb 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Waste ink tank full on a Ricoh Africio MP C1500 sp
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
Dec 02, 2008 | Ricoh Aficio MP1600SPF Copier
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Canon imageRUNNER 5020i Copier Logo
107 people viewed this question
old marine
old marine
