Question about Cisco SR520W-ADSL-K9 Router
I just ordered a SR520W-ADSL-k9 Router. I am using SMB 2003 for DHCP now, I guess I should let the router handle DHCP, or Maby the router DHCP to my server and use a different subnet for the server DHCP. What is the best
  • 3,866 Answers
If you want to SEE and use or share files it would be best to use the SAME subnet and DHCP, So one of those DHCP needs to be disabled. It would be best to use the Isp's modem built in DHCP but that is up to your on that.
let me know if you had additional questions.
please do leave positive feedback and ratings, Thanks
Posted on Aug 31, 2010
I AM UNABLE TO CONNECT A DSL MODEM AND ROUTER THROUGH SWITCH. AT A TIME I AM ABLE WORK ONLY INTERNET OR LOCAL NETWORK??? PLZ GIVE SOLUTION
Set the modem back to how it was to start with. Plug it into a computer and make sure it is working.
Plug the modem into the routed port on the router. This is labelled ADSL on the one I have here, yours may be different - regardless it's the one that goes to the outside world.
Set the router to factory and plug the LAN side into the switch. Let the router handle DHCP for the LAN and the modem provide DHCP for the router. This results in two layers on NAT, but it's easier than figuring out how to put your modem into bridge mode.
Apr 02, 2012 | Computers & Internet
Hello, I am currnetly using a Belkin ADSL2+ modem with wireless G Router and have just been given a D-Link Dir-855 Xtreme N Duo router I wish to use and have been told I can buy a ADSL Modem only to...
I think there is no need to replace the ADSL2+ Router.
Belkin is fine and should work well in combination with the D-Link Router and you would get the downlink data rate up to 300Mbps.
I recommended that you use Belkin Router as ADSL Modem and Dlink to provide wireless access. (Instead of buying ADSL Modem)
So, all you have to do is : -
-Turn-off wireless signal of the Belkin modem.
-Connect the Dlink Router to the Modem (Belkin) through CAT6 Cable.
-Configure the Dlink Router, Secure it and Enjoy 300Mbps Data Rate.
(In this way your Belkin will serve as ADSL Modem and Dlink would be the wireless router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
May 09, 2011 | D-Link Xtreme N Wireless-N Gigabit Router...
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Connecting a second pc to a router
First step is to restart the router, power off then on.
That will restart the DHCP server on the Router.
If the above fails, check below.
Make sure you are getting a IP address from the router.
- Start - Run - cmd - ipconfig
If not check that the DHCP service is running.
- Start - Run - services.msc
If you find that dhcp is working a your have a vaild ip address 192.168.1.2 or 192.168.2.2 something thing like this,
then go to cmd again, and try to PING the default gateway.
Hope this info helps.
Best of Luck.
Jun 08, 2008 | Zoom ADSL 5554 X5 Router (5554-00-00)
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Cisco SR520W-ADSL-K9 Router Logo
111 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
