Question about Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1
The motor is osilating up and down with good oil, fuel.
  • 30 Answers
Make sure your spark plug and air filter are clean. typically when this happens the spark plug isn't firing correctly.
Posted on Aug 31, 2010
  • memahillbill Aug 31, 2010
    thank you will give try
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
Jul 28, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Honeywell hy 013 making noise while osillating
You can replace the control arm screw with a longer one of the same diameter and thread pattern.The longer screw will catch the base and allow proper oscillation motor to catch the base.
Jul 23, 2016 | Honeywell Dryers
Fuel pump problem?
Caution *** For your safety, Installation of this electric fuel pump requires that it be wired through the oil pressure switch
Jul 27, 2013 | 1991 Isuzu Pickup
Yardworks snowblower will not start with electric cord and to hard to crank
too hard to pull may indicate that it is hydrolocked. Fuel from the carb may have leaked into and filled the crankcase. Check the oil level and see if it is very very high. Watch out! The fuel makes the oil level very hard to see. If the oil is filled with gas than not being able to start is a good thing. The motor wont get enough protection from wear with that much gas watering it down! If the oil is watering down then drain it out and get some fresh oil. Make sure you turn off the gas between uses to prevent the carb from dumping fuel. Get the carb serviced to fix the problem too.
Jan 02, 2013 | Garden
1996 chevy silverado 350vortec start and idle good,but when driving 30-40 when i push down on the gas it bogs down and act like it wont to cut off.
Check your fuel pressure because that sounds like a weak fuel pumpor clogged fuel filter.The fuel pressure should be 60-66 psi with the key on and engine off.
Nov 02, 2012 | Cars & Trucks
Camera will not power on
check
camera mother board crystal osilator so clean & some heating osilator.
May 26, 2012 | Panasonic Lumix DMC-ZS8 14.1 Megapixel...
Car firing but will not start plugs sooty
You could try the Clear Flood procedure....Throttle wide open and crank engine . This sometimes works, but.....
These engines suffer from fuel wash down. The gasoline washes away the oil in the cylinders.....and compression goes away, not making the fuel fire off.
The film of oil in the cylinders and rings seals the piston to the bore making for good compression.
Remove the spark plugs....crank over the motor to eject raw fuel...dribble a couple of spoonfuls of motor oil down each plug hole and crank briefly.
Install plugs and try restart.
Jan 14, 2011 | 1993 Jaguar XJ6
When I check the oil it smells of gas motor run strong but why would there be gas in the oil?
your oil may be breaking down,try a really good oil change with a fram oil filter,recommend that you use castrol 30 weight oil in winter and 40 weight in summer,also add lucas oil treatment in with the oil change,it gives great top of motor lubrication,not like regular oil.fram filters are great too,they won't fold under pressure like a cheap one would.when you refine oil,it turns into gas.if you've been using a quick oil change place,stop. find a mechanic that can change your oil. you go to parts store,purchase an oil change kit with 30 weight castrol oil,tell them you want to add lucas oil treatment in on the oil change and have them look up your engine to see how many quarts of oil it takes,make sure they know that you want to add the lucas in on the oil change so you don't overfill the oil.after you've purchased the oil change kit,then go to your mechanic with your supplies and have them change your oil.after you've done this once,you'll do it all the time.quick oil change places buy their oil in bulk and as cheap as possible,then charge you for quality products.they break down quicklyand add very little lubrication to your engine.thank you for choosing fixya.com
Jan 10, 2011 | 1995 Nissan Pathfinder
Fan osillation stop in tower fan model 05545
Check to see that there is power at the fan motor with a volt meter it should be 110-120volts AC. Your motor is probably shot, also you can check the switches to see they are getting power also.
Oct 09, 2009 | Aloha Housewares (93645) Ceiling Fan
Where can I get a part for my Windchaser 16" osilating stand fan, model IVS182. It stopped osilating and needs the small part that helps it osilate. Don't know what it is called.
Check with the manufacturer, they should be able to get you the replacement part. Maybe they show a diagram online with names of parts that can help you name it, so they can send you one.
Hope this helps. Good luck!
Jul 30, 2009 | Windchaser (IVS182A) Stand (Pedestal) Fan
Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1 Logo
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
