Question about GE WCVH6260FWW
WCVH6260fww is not getting water. Just loud noise from the pump in the bottom right. Did the T02 test and results was E23 and E31. Since there is no water coming in, should that be the valve's problem if there is voltage coming into the valve (wh13x10023)?
5 Suggested Answers
SOURCE: I ran the test program and found faults
This is wierd, but I changed the water valves, unfortunately, the company sent me a replacement that was not exactly the same, I drilled one hole and mounted the new valve set. After installing the valves, I ran the machine in order to run the diagnostics, all worked, and all is fine now. Going on nearly two months, and all stil seems to work. I believe the hot water valve was shorted out, causing the computer to crap out...
Posted on Jan 29, 2008
mumma_1
  • 903 Answers
SOURCE: Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Posted on Oct 30, 2008
  • 106 Answers
SOURCE: GE model WCVH6260FWW is leaking from the middle of the front door
http://www.fixya.com/support/t249922-ge_frontloader_door_gasket_ripped
Posted on Mar 02, 2009
rylee_smith
  • 8619 Answers
SOURCE: Its not pumping in any
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 03, 2010
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
No hot water cycle on ge wcvh6260fww
You need to replace the water inlet valve. Here is the part to order.
I have the complete service manual available if you should need it, post your email address.
Feb 17, 2013 | GE WCVH6260FWW
T02 error code 30
E30 means that the control isn't getting an electrical signal from the water pump. A clogged pump, bad pump, loose connection or a bad control board can cause this error code. The first thing you will want to do is check for a loose connection. Then make sure the pump isn't clogged. Check the pump motor with an ohmmeter and if it is open replace it. At this point the only way to tell if the control or the water pump is the problem is to run the water pump test on this page
Test for voltage at the pump during the test. If the pump is getting power but will not run, replace the water pump and if the pump isn't getting power, replace the control.
Sep 07, 2012 | General Electric WCVH6800J Front Load...
My Ge front load wcvh6800j1ms leaks from the bottom, water continues to run, and won't wash
Sounds like you could have a pump problem or a loose hose. First, go ahead and clean the drain pump filter (as per instructions in the Use & Care Manual). Screw it back in tightly to see if that resolves the issue.
If not, check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you don't get any error codes and all tests run correctly, open the front access panel and see if you can figure out where the leak is originating from (To remove the panel: undo three screws and lift from the bottom).
Good Luck.
Jun 10, 2011 | General Electric WCVH6800J Front Load...
My GE model wcvh6800j1ms front load washer leaks water a bit from the front right side, any thoughts?
Front right would most likely be the discharge pump. Here's a diagram:
Please post back once you either have codes or have located the leak source...then we can troubleshoot more.
Apr 18, 2011 | General Electric WCVH6800J Front Load...
Leaking from front lower right side
Sep 06, 2010 | General Electric WCVH6800J Front Load...
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Make extremely loud noise when you first turn it on and it heats the water and again after each cup of coffee
This the water pump when is working. It should make loud noise. In extreme case in very loud but after a while it become less loud. If just consider that other smaler models have a smaler pump which is silent pump but they dont have it work always so in you case you a very good coffee result.
Jul 10, 2010 | Keurig B100 Coffee Maker
Will not spin. fills up with water but takes a long time to drain. this seems consistent through all modes of operation
The most likely cause of this problem is due to the filter basket being clogged and preventing the water from draining properly. You will need to check the filter basket which is located underneath the washer for obstructions. Don't be surprised if you find lots of change and other foreign objects. To check, remove the bottom panel from the front of the washer with a philips head screwdriver (there are 3 screws). Once you have the panel off, you will find a cap on your right hand side. Don't worry, it's quite easy to spot. Turn the cap counterclockwise to remove. Make sure you have small container on hand as a few pints of water will drain out. Pull the filter basket out and clean. Wipe off the gasket on the filter and receptacle with a clean rag and replace. Thereafter, do this every 6-9 months as a preventative and more often if the problem repeats. You won't find this procedure mentioned anwhere in your owners manual, but it certainly should have been and has been addressed for the newer GE frontloaders. In fact, the new washers have an access panel to make getting to the basket filter easy.
Feb 16, 2010 | GE WCVH6260FWW
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
GE WCVH6260FWW Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
