Question about Dishwashers
My whirlpool adp5966 is stuck on fault code f7 and i dont havee the manual!
  • 3 Answers
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
Remove the filter on the floor of the machine, including the metal grill.
Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it.
My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Posted on Jun 08, 2009
You can download the manual on the whirlpool site. Just enter the model number.
Posted on May 11, 2008
Dishwasher won't start - I get an F7 message on my ADP5966
Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter
Dec 17, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Please could you tell me what an F4 fault is on a whirlpool ADP5966 dishwasher please
f4 fault on a whirlpool ADP5966 dishwasher means (1)Not draining or water level sensor not working . there might be blockage in the drainnage . find the blockage and remove the blockage. Other problems can be wiring or problems with the control board. hope this helps pls do let me know
Jun 06, 2010 | Whirlpool Dishwashers
Whirlpool
you have a water count problem
or a wv1 problem ist easy to solve
Jun 11, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool Dishwasher GU15ooXTLT3
one of 2 things, either you have a bad door switch/latch assy and its not recognizing the door closing, or up have a "stuck keypad" preventing proper operation in which case youll need to replace the keypad/console. if you remove the lower acess panel there is a "tech sheet" explaining different faults and checks for your issue
Oct 26, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
F7-E0 Fault code. All connections and components checked.
Change your temperature sensor first and check if cleared the code. If not change your control board.
Jul 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
F7 fault
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work. The following worked for me: Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Apr 14, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Nov 16, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
My dishwasher has a fault
I am not familiar with your dishwasher, but could you explain the problem you have (does it stuck, on which stage etc..)and maybe this information will allow us to help you.
Jun 23, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
438 people viewed this question
Top Dishwashers Experts
