Question about Cameras
My daughters fuji camera shows a error zoom notice when she turns on her camera. The camera lens door will not open
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Zoom error
The lens mechanism is jammed or broken, the camera needs to be taken apart and inspected. As these kind of  things may break easily oyou might not get it back together..... so try replacing it...
thank u rate me!!
Feb 10, 2009 | Fuji FinePix F650 Digital Camera
Zoom error on my daughters fujifilm a700
Try calling Fuji support and seeing if you can get it repaired or replaced. The camera as it is, is defective.
Dec 29, 2008 | Fuji FinePix A700 Digital Camera
Zoom error
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
Nov 21, 2008 | Fuji FinePix A600 Digital Camera
Fuji a 205 camera zoom error
What has worked for me and what seems to work with both the Sony and Fuji cameras I have had problems with is to get physical with them. Their case is built like a tank but inadvertently jolting, or impeding of the lens during operation, seems to cause zoom problems. If the lens is stuck IN the case (happened to my daughter's Fuji ), then hold the camera in one hand, turn it on and smack it firmly into the palm of your free hand. If it is stuck OUT which is what happened to my Sony Cybershot when it was knocked out of my hand and the lens was skewed to one side was to grab the lens and use reasonable force to realign it, both cameras are now working. In both cases I had little to lose as the Fuji had once before gone in for warranty repair for two months for the same "Zoom error" and the Sony was still under warranty and insured so if I did damge it more after bouncing it off concrete, it would not have been apparent to the repair centre.
These fixes may not cure everyone's ills but I hope my experiences will give you the courage to have a go if you have nothing to lose.
Nov 21, 2008 | Fuji FinePix A205 Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Camera lens cover wont open
Get onto Sony Tech Support team. This is a camera failure the will honour the warranty here I am sure.
Jul 06, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
