Question about Compaq Presario M2000 Notebook
Sound card will not work after installing the driver....says failure
After I run the driver setup program it says failure....can anyone help with my problem?
Thank you!
  • Anonymous Mar 19, 2009
    Sound card will not work after installing the driver....says failure"
  • jajat kurdul May 08, 2009
    when i finish to reinstalling windows, then i install vga driver and other. The vga driver and sound card is not work. I'am try to download driver on internet, but it still can't work.
Im facing the same problem with my compaq notebook !!!!!!
Posted on May 10, 2008
Download the latest driver for your operating system from the Compaq/HP WEB site and install it
Drive problem
Making a jump from XP to Win 7 can be a problem with hardware. In Device Manager is that the ONLY Unknown Device? First we need the IBM model. Win 7 32 or 64 bit? What is the Sound Card, Make model? You can sometimes use Vista drivers, change the compatibility to Win 7.
May 03, 2013 | IBM Computers & Internet
No sound (AsRock P4 Combo)
1.
Check the speaker connections - take the plugs out and put them back.
Make sure the speakers get power.
Test the sound with headphones.
If it is a Laptop be sure the speakers are turned on (Usually an Fn function key).
2.
Load a system restore point from a date before the sound problem started.
3.
Has the audio service been started by Windows?
Click Start > Run > type services.msc - then click OK.
In the new window - Scroll down to "Windows Audio", right-click on it and select Properties.
Another new window - set the startup type to Automatic, click Apply and then click Start.
Have a look in "Play control" and any other sound mixer you may have installed to check if the sound is muted.
Go to Control Panel >> Sounds and Audio Devices.
Check to see if your sound card is listed.
If no audio device is detected proceed to step 5.
Be sure the Volume is turned up (at least half way).
The MUTE box should not be checked (go to the advanced window and make sure that nothing is muted).
Select the proper speaker settings under speaker settings advanced tab.
Set the speaker setup settings accordingly.
Is your sound card the default playback device?
Right click the speaker icon next to the clock >> Choose "Adjust Audio Properties".
Click on the Audio tab and select the correct device.
If you make any changes - click Apply, then OK before you close the window.
If you use another type of audio program, please refer to that program's trouble shooter for diagnostics.
Creative Sound Card owners can try this:
Click Start >> Programs >> Creative >> "Sound Card", for example Audigy >> Creative Restore Defaults.
4.
Check to see if the sound card is properly installed in the Device Manager.
Right click My Computer >> Properties >> Hardware Tab >> Device Manager >> in the "View" menu - click "Show hidden devices".
If there are yellow or red "marks" next to the audio, "Microsoft Universal Audio Architecture (UAA) Bus" or an unknown device - install drivers (see step 6).
If Windows does not detect an ONBOARD (Integrated) sound card >> Check to see if it is ENABLED in the BIOS (Setup).
If Windows does not detect a PCI sound card (an Added sound card) >> Shut the computer down, disconnect power. Take the sound card out and put it back again - if possible, use another PCI slot.
5.
Install available Windows updates, including DirectX.
Go to Start >> All Programs >> Windows Update.
6.
Installing drivers:
6a. Install the chipset driver first >> Reboot.
6b. If a "Microsoft Universal Audio Architecture (UAA) Bus" is present in Device manager >> install the driver >> Reboot.
6c. Uninstall old sound drivers:
Check in Add/Remove Programs in the Control Panel for an Audio device driver (i.e. AC97).
Go to the Device Manager and uninstall the driver (Right click on the device >> uninstall).
Install the sound driver >> Reboot.
The drivers to install can be found on a CD that came with the computer/motherboard/sound card.
Jan 12, 2010 | Asrock (P4COMBO) Motherboard
My Dynex driver wont install?!?!?
your problem it's because you didnt have place your files on the root of the c: , it's a problem with their software, to correct this without copying it to the c: open the folder Drivers_V442a
and then Setup and after that run Setup.exe . After that everything will install and work propelly.
Thanks
May 29, 2009 | Dynex DX-SC5.1 Sound Card
DESPITE PROPER INSTALLATION OF SOUND CARD SOUND IS NOT COMING
When you download and run the sound file, it expands the file and copies it to your hard drive, take a note which folder it has created (usually C:\Driver\) Then open the audio folder and run the Setup program to install the audio driver.
Apr 14, 2009 | IBM ThinkPad R52 Notebook
My m/b is working ok but there have not sound msi 945 gcm5 m/b
hi im josh in cebu phils. may i help you? friend if no sounds working. you need to install the sound card driver built in if you are using sound card built in mainboard or cd if you are using separately. or if it still doesn't work even the software driver is already installed you need to manual setup the software becuase it was installed in the pc but not running to run it go to my computer device manager then click the icon sound then clck update/install driver if browse locate the driver installed in the c folder.then clck run/setup wait til complete then reboot your pc. it will solve the problem. good luck hoped i helped you.
Feb 27, 2009 | MSI 945GCM5 Motherboard
Microsoft UAA Bus driver for High Definition Audio(Driver install
hi im josh in cebu phils.friend if it happens that dsplay or hear sound.you need to install manually the sound driver coz its not yet working right now even installed. All you have to is go the my computer device manger then click the sound card icon.then click installed/ update the driver. if browse go to c program files folder then look for soundcard folder then click setup or run.complete the installation then reboot your pc.this will solve your problem.goodluck.vote me so that i wl know if i helped you.thanks.
Feb 23, 2009 | Computers & Internet
I reinstalled my window xp disc everything work but the sound
sir good day Try Driver Detective try this free tool at http://www.driverfiles.net/page,results,resultpage1.html
youll find it just below sir just download install and run the program it will detect the driver problem automatically for. thnk you and have a nice day.
Dec 14, 2008 | Creative Labs Sound Blaster Live! 5.1...
Need sound card driver
Hi Rana,
Assuming you're running Windows XP or 2000, you can download the PCI 128 Sound Card Driver Installation programs here:
http://support.creative.com/downloads/download.aspx?nDownloadId=255. (They are free of charge, of course).
When you launch the program, it detects your operating system information and automatically installs the appropriate drivers.
If you're running something other than Windows XP or 2000, go here: http://support.creative.com/Downloads/searchdownloads.aspx to find additional driver installation packages.
Hope this helps, and enjoy the sound and music!
Gail :-)
Nov 29, 2008 | Compaq Creative Sound Blaster PCI 128...
The Creative Sound Blaster Live 5.1 Card is not working Or detecting in windows vista
Creative doesn't have Vista drivers for that video card so unless you use some hacked drivers it probably wont work.
Oct 09, 2008 | Creative Labs Sound Blaster Live! 5.1...
Compaq Presario M2000 Notebook Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
