WD Caviar SE 320g Hard Drive
I installed new hard drive in my computer and then I put in the installation disk that came with it. It started reading the installation disk but then it said: Int 13 level communications attempting Int is IO to drive 80 No Response. Then below that it said: ATA Level Com attempting PM ATA Identify. Then it stopped doing anything.
  • Zarlow Sep 06, 2008
    isnt there a fix this for dummies section? ive read some folks installing 500g drives in the same computer. i been researching the web to try to figure out how to fix this prob but only get more confused. dell demension 4600 80g hard drive is dead replaced with a wd caviar se 320g same error message and have tried billions of solutions. is there a person that can explain this in laymans terms (if there is such a thing) to a puter dummy?
  • colossus_n_d Nov 17, 2008
    it keeps saying ATA Level communications when installing a 160gb hard drive trying to replace the hard drive the comp came with and i am confused on what to do
  • 24 Answers
Hi lowlowride,
How is old is your computer and what OS do you have in it? (better to check the specifications or your gear). The Int 13 error actually refers to the limitation of some old BIOS and old OS in handling large drives (like that 320G drive that you have, for details about this error, see http://www.pcguide.com/ref/hdd/bios/sizeGB8-c.html and or http://en.wikipedia.org/wiki/INT_13), this means that your BIOS or OS can't handle it properly, to isolate you can perhaps try updating your current OS or upgrade to a better OS (if possible), if you have another board that you can try better, if not it might help to update your board's BIOS as well though I warn you to exercise extreme caution in doing so if you don't want to fry your board. Hope this helps
Cheers and best regards,
Posted on May 09, 2008
I just bought WD Caviar Pata 320g. The problem is that when I install the software I keep getting "Disk failure install System Disk" what do I do?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 31, 2010 | Western Digital Caviar SE WD800JD SATA...
My computer HDD have bad sactors please help to remove this on
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Installing Hard drive in external caddy
No, you don't remove the board. The drive won't work without it. Just install the drive in the case and connect everything up. The computer will find it and assign a drive letter to it.
Feb 03, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
PLUGGED 19V INTO 12V DC DISC DRIVE
You might try WD's website to see if you can get a new board for the drive.
Feb 28, 2009 | Western Digital Caviar SE WD3200JS...
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Need to install OEM Windows 98
ok you need to reboot your computer from the CD rom with xp disk in it.
start your computer hold down the f12 key, a small menu will come up , pick cd/dvd/cd-rw drive with your arrow keys ,
select enter , follow xp directions on how install operating system on the monitor.
Jan 15, 2008 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Installing new hard drive
hi,
its brand new right? have it reformatted for the first time. you can do this by installing an OS and it prompts you to reformat it. actually, there are other ways to do that but for me, this is the most secure way to reformat a new harddrive in your situation.
hope this helps.
Jan 12, 2008 | Western Digital Caviar SE WD1600AAJS 160...
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
