Question about Moen Home
The moen shower pullout type hot/cold valve will not slide out of the main valve body even after the retainer clip has been removed. I found some corrosion on the retainer clip and I have sprayed the area with WD40 to loosen the corrosion but still unable to get the stem and o-rings out of the valve housing. Help
  • 490 Answers
Howdy, those can be like pulling teeth. The wd40 will not help that much as it is not a robust solvent. I suggest letting some liquid wrench sit overnight on it and then pulling real hard. Good luck:)
Regards,Farmerbear
Posted on Aug 31, 2010
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Jan 02, 2011 | Moen & One Handle Tub & Shower Faucet
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Low pressure on hot water side
I would recommend that you replace cartridge. To do this shut off water supply to tub or whole house as needed, Remove valve handle cover,remove handle screw and pull off handle. Remove chrome cover from around valve body. There is a small brass or copper clip that fits on front side of cartridge to hold it in place. Carefully remove this clip as you will need it for reassembly. Grasp end of valve stem with pliers and gently try to pull cartridge ftom valve body, If it is stuck you can purchace a moen cartridge puller at most hardware stores. Follow directions on how to use puller, remove old cartridge,install new one . install clip moving cartridge slihtly to proper position so retainer clip will slid into position. replace chrome cover and handle and screw and cover. Turn water back on and you should be done. Hope this helps. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
What is wrong with my single handle shower fixture in that it does not give out enough hot water
This is a common problem with Moen shower valves and fairly simple to fix. The pressure balancing cartridge is sticking inside. You need to remove the cartridge and clean it with white vinegar. The problem appears in valves that are not used very often - like in a guest room shower. The impurities in the water leave a varnish-like residue that causes the element to lock up and restrict hot water flow. If you are the original owner Moen will send you a free replacement cartridge but cleaning the one you have will do the trick. Once it's working be sure to run the hot water at least once a week. Here's how to fix it:
1. Turn off water supply to the house or at the PEX panel if you have one.
2. Remove handle by loosening the set screw at the bottom of the handle and pulling off.
3. Remove escutcheon plate by removing 2 screws on the face.
4. Remove escutcheon tube surrounding the valve by pulling with a needle nose pliers.
5. Using an awl or small screwdriver pry the retaining clip up and remove - DON'T DROP IT behind the tile!!
6. Using a pliers, pull out the cartridge. If it won't budge you can try some WD-40 or PB Blaster and if that doesn't work you'll need to buy a "Moen Cartridge Puller" (about $13 @ Home Depot) and it will come right out.
7. Shake the cartridge. If it does NOT rattle you've found the problem. Soak it in white vinegar for 15 minutes and try shaking it again and repeat till you hear the pressure balance element move back and forth. A shot of PB Blaster also helps.
8. Once the element is moving freely you can reassemble everything by working in reverse - don't forget to reinstall the retaining clip or the cartridge will become a missile! TIP: To prevent dropping the clip tie a string through the hole in the top and tape the other end to the wall. If it slips you can just pull it up. Also, spray a little PB Blaster in the valve body before inserting the cartridge to make it easier to seat it.
Hope this helps!
Sep 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Water temp. regulate
Moen faucets have only one moving part. The stem slides up and down to open and close the faucet and rotates to regulate the flow of hot and cold water. Any leaking requires replacement of the cartridge.
First, turn off the water. To remove the cartridge, you'll need to remove the handle. This project can be like working a puzzle. If you have the manufacturer's instruction sheet for the faucet, you're ahead of the game. Without it, look for a retainer clip at the rear of the faucet just below the handle. Or, you may have to remove a set screw or snap-in "hot-cold" button and a handle pin or screw. On some faucets the swing spout must come off first. The retainer clip may be hiding beneath the handle inside a lift-out tube. Some cartridge faucets use two retainer clips–one by the handle and another by the cartridge. Retainer clips can be pried out with a screwdriver.
Once the retainer clip is removed, the cartridge simply pulls out. Use pliers, as shown in Fig. 6. Install the new cartridge by pushing it into place with the flat arrow, or other mark upward. If you use a lubricant on the cartridge, make sure it's silicone grease.
Check and clean the cartridge inlet ports. Before you button up the faucet turn the water back on for a minute to flush out the supplies. I had to look for this answer, hopefully this will work for you.
Jul 21, 2010 | Moen & One Handle Tub & Shower Faucet
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
Not sure if it is a Moen. It is about 30 years old. It has a single handle where you turn on and adjust the temperature, and a shower head and tub spot. Also has a round piece at the bottom of the tub...
Close the stopper at the bottom of the tub - this is so anything you might drop doesn't get into the drain. The drain should not be involved.
You will need to remove the tub/shower valve handle and decorative plate first. Behind the decorative plate there should be a shut off valve on each side of your valve. They will probably be slots to accept a big screwdriver. Turn both the hot and cold water valves off by turning them clockwise until they stop. Do not overtighten them.
Then take a pair of pliers and rotate or pull the tub/shower vale out toward you. You are now testing the shut off valves to make sure they hold before you go any further. If they don't hold and water keeps flowing from either side, you may need to turn off the water to the room or even the house. Hopefully, this won't be necessary.
The shower valve should be a cartridge that can be removed. You must remove a retaining clip that holds the cartridge in place. The clip can be removed with a small flat head screwdriver or needle nose pliers. Do this carefully.
Once the clip is removed, you should be able to remove it by pulling it straight out. This may take a little force. Use the pliers again. If it's stuck, they make a removal tool, but hopefully you won't need it.
Once the cartridge valve is out, take it to a home improvement store and they should be able to match it up. Given its age, the valve may have to be ordered.
When you re-install the cartridge, pay attention to it's orientation. The worst thing that will happen is that the hot and cold could be reversed, but that can be corrected by removing the cartridge, flipping it over and re-installing it. Put a little hand liquid hand soap on the new cartridge when you install it so it slides in more easily. You should have received a new clip with the new cartridge. Open the shut off valves slowly.
Test the valve for hot/cold orientation again and look fo any leaks before you re-install the decorative plate and valve handle.
Jan 14, 2010 | Moen & One Handle Tub & Shower Faucet
Using a moen cartridge puller and still cant get cartridge out im using a lot of power but no luck
Haave you removed the U clip? It slides down from the top of the valve body. They can be hard to remove but will come out.
Nov 02, 2009 | Moen & One Handle Tub & Shower Faucet
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
104 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
