Question about HP LaserJet 3380 All-In-One Printer
Doc feeder problem with adf unit
Machine cannot copy and send fax through adf unit
  • Anonymous May 10, 2008
    printer not feeding. I have to push through manually to get it to print.
  • janhavi ghanekar May 13, 2008
    with this solution problem not solved.
    Problem Solver:
  • 15 Answers
First check the copy wheather it is working it or not after that if it is working then try to fax and also check the phone line
Posted on May 09, 2008
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Tip
Black lines when sending faxes or making copies
I've been getting many calls asking me why their fax/copiers/printers are getting black lines when they send faxes and making copies while using the automatic document feeder, and not when they open the document feeder and use the glass.
What happens, when you fax or copy papers that has white-out or some material that can flake off, it gets embedded on the ADF glass and the unit thinks its part of the paper.
99% of the time, what needs to be done is to clean the small glass, usually using fingernails to scratch off the dirt, or using a lint free cloth slightly moistened, should do the trick. Just go over it several times until it comes off.
If the lines are thick, it usually indicates a damaged scanner assembly, in cases with the Brother machines, not expensive to fix. With other units, its a different story, either because they do not sell the scanner assembly as a part, or units are sent in for whole unit repairs.
on Jun 08, 2010 | Office Equipment & Supplies
I have a 8840D. the doc feeder became unglued from it hinges on the base of the machine. Also it does not feed docs any more.
you configure your printer adf insert paper adf congigure copy quantity button press print key then make copy how much quantity
thanks
reply me comments
Sep 10, 2009 | Brother MFC-8840D All-In-One Laser Printer
Copy Function not working
You need to reset the machine back to factory defaults
Turn machine off
lift up doc feeder and hold down the pointed switch by the scanner glass while turning the machine back on until it beeps.
Close doc feeder
scroll down to SHIPMENT SET
press SET
SET
wait for the machine to reboot.
Aug 04, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Black lines across copies
try the drum, replace and make a copy
Aug 18, 2008 | Sharp AL 1631 Copier
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
Problem with sending faxes
change a paper size in the fax setup
Feb 04, 2008 | Office Equipment & Supplies
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
HP LaserJet 3380 All-In-One Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
