I have a four year old central a/c system (horiz. mount in attic) The bottom of the airhandler is dripping water into the secondary drain pan. I checked the drain for blockage, freon preasures and air flow. It all checked OK I replaced the coil and primary drain pan. Water is still leaking!!! WHY???
  • 11,896 Answers
I get lots and lots of inquiries about water leaking from air conditioners and heat pumps. This is a very common problem that is easily solved. The way your air conditioner dries your house is by removing moisture. That moisture must go some where. The moisture is removed by condensing it on the cold refrigeration coils and letting it run down a drain pan.
The problem is that dirt and crud will stop up the drain line and clog the pan. This will eventually happen to every system out there give it enough time.
While this problem makes a terrible mess and seems like to end of your system it is really quite easy to fix. Most system simply use a 3/4 inch PVC pipe to drain the water to a floor drain or sink. when (not if) this drain clogs the drain pan over flows (especially when the fan stops) and you have a mess.
Fixing this problem is rather easy. Simply take a wet dry vacuum and **** the drain line clean, 9 times out of 10 this will fix it and that is the last of this problem you will have for a few years. If the drain pan is really dirty then you will have to take the covers off the unit and vacuum it out. In extreme cases you may have to use compressed air, nitrogen or CO2 to blow out the drain line (expect a big mess at the other end).If you don't have either avaliable you can use the Garden hose to flush the line backwards (expect an even bigger mess on the other end)
In rare cases you may actually have a hole in the coil drain pan in which case the coil or the pan will have to be replaced especially if it is steel (but this is rare). In other rare cases we have had situations where grease or oil fumes from the furnace have condensed on the coil and caused the water to fall off the coil. When this happens you must clean the coil with soap or some solvent.
If the coil is totally stopped up the back pressure from the fan/blower can force the water out of the pan by undermining the bottom of the coil. When the coil is this dirty the coil ussually needs to be replaced. You will also notice little or no air flow.
Posted on Sep 09, 2010
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
Dec 27, 2014 | Heating & Cooling
I have a Carrier central air unit in the attic. There is water dripping through the ceiling. There is a problem with the internal drain pan, as the unit drips a LOT of water into the emergency pan. There...
The internal catch pan is very time consuming to replace, especially since it is located in the attic. But before you try that, have you checked to see if the drain line is clogged with algae and that it has the one inch to one foot drop you need for proper drainage? Has you house settled throwing the slope off?
If you live in the South algae growth can clog you drain line. I would disconnect the drain line (have a bucket handy) and see if it is clogged. If you have algai growth then you need to treat with bleach to kill it off. You might also want to run a drain snake through the rest of the line to make sure that it is clear.
Jun 05, 2011 | Carrier 38CKC060 Air Conditioner
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Condensate drain not working. Water driping from entire attic unit. Have flushed and vaccumed line to no avail. Secondary tray does drain but water drips outside the tray area. American Srandard Allegiance...
the drain coming off the unit is the one you need to clear, not the secondary pan. its usually clogged in the P trap which is usaully not far downstream from the outlet on the coil.
Sep 13, 2009 | Heating & Cooling
My frigidaire central ac unit and secondary water valve
Yes there is a problem the primary drain is clogged up with crud an your aux. drain pan is full and draining through the emergency drain line
FIND THE OUTLET OF THE PRIMARY DRAINLINE SHOVE A WATER HOSE IN IT TURN IT ON AND COUNT TO 10 AND PULL THE HOSE OUT WATER WILL COME OUT THEN LOTS OF SLIME THEN YOU ARE DONE REPEAT THIS PROCESS ONCE EVERY 3 WEEKS DURING THE SUMMER
Aug 11, 2009 | Heating & Cooling
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
Vertical to horizontal
most all airhandlers have a second pan included . if not they can usually be purchased with directions to mount to the side of the coil for horizontal right or horizontal left application. remove the front panel and take a flash light look inside and you should see a cookie sheet looking pan on one side of the coil usually on the right side coil can usually be removed and reinstalled with the top of the coil facing the filter or the blower depending on how you want the air to go . just be sure the pan is under the coil and you will be ok . i have actually seen pros install them with the pan above the coil! and of course they flood the place. water of course goes down hill. the square donut pan used for vertical install stays in place as found. you will need to install a second emergency pan to catch any backup drips especially if you put it in an attic. you should find them at a sheet metal shop and they are basically a pan even bigger than the airhandler that catches any drip. it should be connected to a drain to the outside also and a float switch installed in case it fails to shut off the ac. better to get a no cool call than a flooded house call. try to put the second drain out over a door or window where it will be noticed before damage. good luck and remember you will have to relocate ductwork, electric drains filters refrigerant lines and if its in an attic a decked service area and a light and an outlet are required here in fla. good luckagain.
Oct 25, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
