I just bought a new Beklin 'N' Draft Router,I followed the simple instructions and the Amber Moden light on the router never turns Green meaning all is working, Could this router be Bad ?
Sincerely
Alan Ryan
If the green light is one of the port lights, then your network is switching into 10mbs (Orange = 10mbs, Green = 100mbs) - it may be a dodgy cable but more likely a faulty network card in your PC.
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
1. A solid amber light means that either you have lost connectivity with the ISP or you have a power supply malfunction. Contact the Internet Service Provider to check your line connectivity to your premise. 2. There is a caption under the light that will tell you which it is . If a cable it will say "link". If DSL it will be "dsl" . Your power will be "pwr" or Power and it will be green
The second light is for your wi-fi protected setup. If it solid green then you have a secure connection. Blinking means looking for device. Amber means a connection was not connected. Off means idle.
has it worked before? if so, try to power cycle the devices by turning off everything. then turn on your modem first, wait for the lights to turn on on the modem before powering on the router. check if you're online
but if the router is for initial setup, you can try to run the cd first and follow the instructions. you need to make sure also that you can access the internet directly from your modem
hope this'll help you but if you still experience the same problem, just provide your ISP, the model of your modem and how are you connecting the devices
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
