Question about Frigidaire Affinity ATF7000E Front Load Washer
I washed a feather pillow and it exploded in the washer. Now the washer doesn't run. I cleaned out the exit hose, but still the washer doesn't work.
5 Suggested Answers
SOURCE: samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Posted on Mar 08, 2009
falter
  • 245 Answers
SOURCE: I need to remove the drum to clean the inside part of it
go in touch with BOSCH customer service and tell them ur problem....i don't think u have to remove the drum to fix ur problem.....so find out yourself from bosch......good luck
Posted on Mar 12, 2009
heatman101
  • 43501 Answers
SOURCE: daughter washed a feather pillow which fell apart
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 30, 2010
jharvey572
  • 447 Answers
SOURCE: my wife washed a pillow
ONE WAY WOULD BE TO DISCONECT THE PIPES IN THE WASHER TO MAKE SURE THERE NOT CLOGED UP
Posted on Jul 30, 2011
Washer won't drain
Probably the pump is clogged with wet feathers. It will have to be cleaned out to restore normal operation.
Apr 17, 2018 | Washing Machines
Washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Sep 05, 2012 | Washing Machines
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
Mar 12, 2009 | Bosch Exxcel WFO 2864 Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
114 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
