Question about Philips bSure SV1 Multimedia Projector
Can not get it to focus correctly on promethean board
IBENEZ BASS AMP P500H NO SOUND
I had a short at one of the electrolytic capacitors at the EQ board. Check the voltages!
Apr 11, 2014 | Ibanez P500H Promethean Bass Amplifier...
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
Prm35 white dots
The white dots mean that the DLP chip has dead pixels. This can't be repaired by your average Joe or Josephine. The only time I ever "fixed" this problem (I fix these professionally), was when I happened to have another PRM-35 that had a bad power supply board. I was able to take the whole lens assembly (which includes the DLP chip) out of that machine and put it into the one with the little white dots. Check and see if it is still under warranty. If you have some extended plan, maybe you can get it replaced.
Feb 24, 2014 | Promethean Board Promethean PRM-35 DLP...
Prm 25 projector
Not what you want to hear but this error means the lamp did not ignite. The most common problems I have had with projectors has always been the lamp itself, so if you have another or know someone with a good lamp try that first.
Jan 15, 2014 | Promethean Board Lamp for PROMETHEAN PRM25...
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
Flickering
Did you check your cable? if the connection is bad the image will flicker in and out.
Oct 24, 2012 | Promethean Board Lamp for PROMETHEAN PRM25...
The projector projects a purple light on my Promethean Board.
Assuming you are using a DVD player your cable is correctly plug.
Your projector input is not correct try pressing your input button and wait for graphics atlest 10 seconds before pressing again. repeat sequence till you see the graphics.
Dec 10, 2010 | Hitachi Office Equipment & Supplies
I have a Promethean Interactive Board in my classroom that is paired with an Epson 83C projector. The picture that is blurry. How can I focus the picture on the Promethean Board? Thanks!
the light is blerry ,
Pls check the lamp,(if it is bright enough )
check the color if it is correct and brite-colored (if the LCD panels is work well)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 01, 2010 | Epson 5300 7200 7300 Replacement Lamp -...
Philips bSure SV1 Multimedia Projector Logo
119 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
