Question about Poulan Garden
It has a new battery, but it do'nt turn over good enought. the spark is good. It has a new plug.
  • 252 Answers
If this engine is a briggs ohv unit
try adjusting the valves so that decompressor can do its thing
and decompress the engine for easier starting
valve clearance is sett @ 1/4 inch tdc on power stroke to 0.003 " inlet and 0.005" exhaust
on briggs alloy push rod is inlet and steel one is exhaust
the bottom valve assy is inlet and top one is exhaust
because of cross flow design of engine
but check battery positive cable and negative cable to earth and make sure good connections - check your starter motor earthing and bushes
if kohler engine with hydraulic lifters make sure you use 10w/30 oil not sae 30 oil or it wont decompress properly
cheers
Posted on Sep 01, 2010
I got lancer ck2 model 1999 year I start the car bt its nt possible.i hv new battery everything bt still cnt start whts wrong help
When you turn the contact key; do you hear the pump humming? Do you have power going to the ignition coil? Is the power going to the spark plug? (unscrew one, lay it on the engine connected to its wire, check for a spark when activating the starter.)
Jul 11, 2015 | Cars & Trucks
Spark plugs cbr
do not understand quwstion if you want to upgrade your plugs go to honda tech on google and they should help you
Apr 15, 2014 | Honda Motorcycles
Plugged in not charging
Is your new battery capasity higher than the other one you used before? If so, than the charger may not support or have enought wattage for the new battery
Feb 19, 2014 | Dell Latitude E6500 Laptop
Electrical
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
From start to end troubleshooting these problems I suggest you to check the help link below and follow its procedure: -----
Mostly all types of car no start problems are discussed here with solutions:---
CAR NO START: ENGINE NOT TURNING OVER:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html
These will help.
Thanks.
Dec 07, 2012 | Dodge Protege Cars & Trucks
I have a 2003 Ninja 636 that has been sitting for 3 years. I just changed the battery and added new gas to the old gas that has been in the tank for the last 3 years. It still wont start. Any trouble...
Sheeesh 3yr old gas is'nt gas any more, drain the tank and fill with 93 octane add injector cleaner. change spark plugs. Be prepared to charge battery. Good luck!
Aug 16, 2011 | 2004 kawasaki ZX-6RR
I put new plugs in and a new battery. It will
No it cannot. If the switch was bad the bike would not turn over. Use an old plug to check for spark. Just pull one of the plug wires off the plug in the engine and shove the loose plug into it. Ground the metal part of the plug against the engine and turn the engine over. If you have no spark the wires on the starter relay switch could be your problem. Make sure they are all clean and tight. Ditto for the wires on the battery. If you have spark smell the exhaust pipes. If they stink the gas in the bike may be too old to fire. If it stinks like a dead rat you need to drain all the gas you can out the bike ( carbs too) and replace it with live gas. If you have spark and good gas is there any possibility you accidentally reversed the plug wires?
Good luck.
Mar 19, 2010 | 2000 Suzuki VZ 800 Marauder
Kazuma Panda 110 Quad - Starting problem
have you tried a new spark plug???? try new sparkplug there may be a spark on the old one but it may not be strong enought, if that dont work you know its petrol problem!
Nov 22, 2009 | Quad Cycling
97 sebring lxi, 2.5L - car died leaving driveway. wont start. been running fine, no noises, hiccups and nothing when it died. battery good, changed plugs, fuel pump buzzes when key is turned, engine cranks...
first thing you got to do is determen weather its electrical or fuel problem, you can take a test light and hook to a ground and the light end to a spark plug and see if it lights while someone turns over engine, if it lights you got spark. if its got spark, on to fuel, take fuel pressure test, don't think because you can hear pump working does not mean it is, it can sound like it is but its not, at least putting out enought pressure, not the correct amount it will not run. pumps will go out just that way with no warning at all.
Feb 03, 2009 | 1997 Chrysler Sebring
Garden Logo
170 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
