Question about Microwave Ovens
Phillips whirpool v i p 27 microwave has stopped, the small little board in the oven (could be filter) is clogged through years of use is it possible to replace this or get this model repaired
  • Microwave Ovens Master
  • 9,098 Answers
Can you post a photo of the board?
Any filters should be shown in your manual.
Posted on May 09, 2008
  • William Miller
    William Miller May 09, 2008
    Sorry - I meant to post that as a clarification request, not a solution.
    Can you post a photo of this board?
Microwave oven whirpool model mt1100shq,it was workinh fine suddenly stopped and no power coming to it
Check the mains power to the microwave before you check for power to the unit. If the program controller is not working , check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Feb 11, 2013 | Microwave Ovens
Tip
I like any microwave apart from the Phillips whirlpool Vip 27
I have a Phillips whirlpool Vip 27 and it still works (which is unfortunate because I like any microwave apart from the Phillips whirlpool Vip 27) so I am wondering if I should recycle it or give it to a charity because it's got a crack in it and I like any microwave apart from the Phillips whirlpool Vip 27 I hope to get rid of it and get a new one and if the Phillips whripool 27 became available again then I would never buy it again so goodbye Phillips whirlpool Vip 27
on Nov 23, 2016 | Microwave Ovens
My whirpool oven model no akz 456 stop heating
The magnetron or the inverter board are the likely cause if microwave is less than 7 years old.
Jun 02, 2012 | Whirlpool Microwave Ovens
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
May 08, 2012 | Samsung Microwave Ovens
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Whirpool microwave resetting clock
Whirlpool Microwave X2-30ES
I was pressing one too many buttons.
Press Clock, then Stop, press in the 24 hour time digits, then press Clock again.
Nov 02, 2009 | Microwave Ovens
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Panasonic NIE1880 BP SC80310019
Service Code F84:
These codes may be triggered by either excessive heat within the oven or poor grounding of either the temp sensor or the controller (DPU) board. Check the following:
a) Clogged air filter (not applicable to OCS models)
b) Obstruction of the exhaust duct or insufficient ventilation
c) Defective thermal sensor (should read 30 – 70 kohm in room temperature)
d) Grounding of the thermal sensor (possible oxidation)
e) Poor connection (oxidation) at CN4 connector (PRO-1 models only)
f) Poor or no ground at the controller (DPU) board – ensure that all screws securing the board are in place
g) Missing screw(s) that secure the escutcheon to the frame (OCS models only)
h) If all steps above check OK, the error(s) may be caused by defective controller (DPU) board
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Panasonic NN-S933BF Microwave Oven
Microwave Ovens Logo
107 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
