My printer says to insert fuser and I don't know how to do this.
  • tds9 Aug 31, 2010
    It is a Xerox Phaser 6140
  • 19,396 Answers
Hi.
The fuser lamp is often enclosed in a cartridge that is slided inside the machine position of the fuser is underneath the toner cartridge, where the toner dust is released from the cartridge.
I can be more specific on fuser replacement operations if you tell me make and model of your printer.
Posted on Aug 31, 2010
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Tip
What to do if your ricoh 1022/1027/270/220 copier show SC452
To who had encounted this problem:
1. Don' t panic as the copier jammed temporarily
2. Switch off the copier
3. Open the lateral door,take out the fuser unit & replace the 2 unit termistor unit with the new unit [cost around us30]
4. Insert back the fuser unit then closed the laterl door
5. You have to reset the copier, below is the process:
6. Switch on the copier
7. Push button cancel[yellow] with button 1, 0,7 then follow
on Apr 16, 2010 | Office Equipment & Supplies
I have an imageclass mf3240, it intermittently prints out wrinkled pages. I would like to see if it is repairable, i did only pay $200 3 years ago so if it is cheaper/easier to just buy a new one I will. I...
Hello Lea! Welcome to FixYa!
If your printer prints wrinkled pages then first of all it may be because of paper jam or paper tray, their may be a small sheet of paper remain inside causing problem or the paper tray is not properly inserted, So check there must not be any piece of paper or if paper tray is not properly inserted, Insert it correctly.
If problem is still there then this problem is usually caused by the Fuser assembly or Tension Roller of the printer. You need to change the tension roller of the printer and if need then change the Fuser Assembly. My advise is as it is technical hardware problem so you must consult with Canon Authorized Center and they will replace the roller of the printer and if there will be need they will change the Fuser Assembly of your Canon image Class MF3240 printer
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Mar 03, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
I getting 50.2 fuser error in hp laserjet printer what i do i don't know can u any one help me
the 50,2 error is a fuser error, and should be serviced by a repair facility. You can try to replace the fuser yourself, but the labor should be pretty cheap compared to the cost of the fuser assembly.
May 06, 2011 | HP LaserJet 5100tn Printer
It just says fuser error and I don't know what to do?!
Remove the fuser unit from the laser printer, check the two spring contacts are clean and insert it back into the printer. The fuser unit will be very hot if it is working.
If the printer still gives this error message then the fuser unit may be faulty and needs replacing.
Mar 23, 2011 | Office Equipment & Supplies
Engine fuser error
The fuser unit may not be seated or inserted properly.
Try removing the fuser unit and insert it back into the printer. Make sure the two spring contacts in the fuser unit are seated firmly.
Mar 12, 2011 | HP LASERJET P1005 Printer
Problem
You don't unless you happen to be a service technician.
The fuser is one place where you can get hurt playing around.
Also, most manufacturers will treat fuser id as a proprietary and you have to know the fuser id to change the data field.
Don
Feb 19, 2010 | Konica Minolta bizhub C351 All-In-One...
The printer display says "Open Heat Error". What is this and what causes it?
I'm not real sure but I do know the the fuser area contains heat sensors. If the fuser temp is higher than it should be, you will get over-temp errors.
Get the printer serviced. It very well could be a motherboard failure or a fuser control card.
Don
Feb 18, 2010 | Dell 1600n All-In-One Laser Printer
Fuser error 50.1
turn off printer and unplug it.
remove the fuser
wait 20 minutes
reinstall fuser
insert power cord, power on.
wait for it to initialize.
If error comes back...you've got a bad fuser or power supply
Jan 27, 2010 | HP LaserJet 2840 Printer
jasbo
jasbo
